[mapguide-users] Problems with base layers.
RenoSun
renolionheart at gmail.com
Thu Dec 22 12:14:00 PST 2016
Hi Martin,
I actually tried the method you mentioned before.
My temporary solution is to put only one map on each fusion layout, and I
switch fusion layout by calling fusion through iframe.
However, if you would like to see the same extent, you will have to
customize FusionSF.js to achieve that.
It's on our public GIS :)
Property Map <http://maps.qualicumbeach.com/QB/Property.aspx?m=Property>
Will let you know if I find a real solution for this issue.
Cheers,
Reno
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problems-with-base-layers-tp5298092p5301119.html
