[mapguide-users] Adding custom command in react layout
TabrizSoftware
Ali_Akhavan2 at yahoo.com
Thu Jan 26 06:31:04 PST 2017
Hi Jackie,
I have a question about execute *setScale *command from
a function in /application.tsx/
i want to add function in /application.tsx/ to communicate
custom ui (in template) with Mapguide react
application.tsx
import * as React from "react";
import * as ReactDOM from "react-dom";
import { Provider } from "react-redux";
import { IAppProps, App } from "../containers/app";
import { ClientKind } from "../api/common";
import { ClientContext } from "../api/client";
import configureStore from "../store/configure-store";
import { INITIAL_STATE } from "../reducers/config";
import * as MapActions from "../actions/map";
* This is the entry point to the Application component
export class ApplicationViewModel {
constructor() {
public mount(node: Element, props: IAppProps) {
const agentConf = {
agentUri: props.agent.uri,
agentKind: props.agent.kind || "mapagent"
const store = configureStore({ config: { ...INITIAL_STATE,
...agentConf } });
ReactDOM.render(<Provider store={store}>
<App {...props} />
</Provider>, node);
public setScale_To_20000()
// I don’t khnow how to call _setScale_
function
return 'Ok';
Index.html
var el = document.getElementById("map");
var viewer = new MapGuide.Application();
viewer.mount(el, {
layout: "ajax-viewer",
externalBaseLayers: [
{ name: "OpenStreetMap", kind:
"OSM" },
agent: {
uri: "../mapagent/mapagent.fcgi"
*viewer**. setScale_To_20000();*
View this message in context: http://osgeo-org.1560.x6.nabble.com/Adding-custom-command-in-react-layout-tp5304940.html
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20170126/45052ab6/attachment.html>
