[mapguide-users] Adding custom command in react layout
Jackie Ng jumpinjackie at gmail.com
Tue Jan 31 04:26:33 PST 2017
Are you trying to automatically go to a certain scale on viewer startup? If
so, there is no hook or extension point to allow for this at the moment.
Please note that the viewer customization story (beyond the same InvokeURL
command mechanism used by AJAX/Fusion viewers) is not yet fully defined.
Until then, I am in no real position to offer solid advice on how you should
approach this problem.
- Jackie
View this message in context: http://osgeo-org.1560.x6.nabble.com/Adding-custom-command-in-react-layout-tp5304940p5305480.html
