[mapguide-users] Fusion Error - MGOS 3.1.2
GordonL
gordon.luckett at arrowgeomatics.com
Wed May 15 12:39:35 PDT 2019
Hi Mike, I have seen something like that when you hide the Overview Map
before its loaded.
For example, if you modify the template for for AQUA and hide the Overview
Map:
//dOverviewMap.open(); (comment out the Open method)
This causes some issues. You would be better to use the load event to check
first and then hide it after the fact..
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
