[mapguide-users] Fusion Error when using Select widget on Mapguide 3.1.2
pmpm
miroslav.poslon at zeljko.hr
Fri Feb 14 04:58:16 PST 2020
When I use Select widget on Fusion to select layer on map I got Fusion Error
Error
Error Details:
Exception occurred in AJAX callback.
Message: h is undefined
Location: http://pms03/mapguide312/fusion/lib/fusionSF-compressed.js (2988)
Inner Stack:
renderLayers at http://pms03/mapguide312/fusion/lib/fusionSF-compressed.js:2988:316
renderSelection at http://pms03/mapguide312/fusion/lib/fusionSF-compressed.js:2987:155
bind/<@http://pms03/mapguide312/fusion/lib/fusionSF-compressed.js:1174:474
accumulateSelection at http://pms03/mapguide312/fusion/lib/fusionSF-compressed.js:2425:320
getSelection at http://pms03/mapguide312/fusion/lib/fusionSF-compressed.js:3106:39
getSelection at http://pms03/mapguide312/fusion/lib/fusionSF-compressed.js:2424:488
updateSelection at http://pms03/mapguide312/fusion/lib/fusionSF-compressed.js:2986:317
triggerEvent at http://pms03/mapguide312/fusion/lib/fusionSF-compressed.js:2333:236
selectionHandler at http://pms03/mapguide312/fusion/lib/fusionSF-compressed.js:2423:393
newSelection at http://pms03/mapguide312/fusion/lib/fusionSF-compressed.js:3102:50
processSelectedFeaturePropertiesNode at http://pms03/mapguide312/fusion/lib/fusionSF-compressed.js:3108:267
onNativeSelectionUpdate at http://pms03/mapguide312/fusion/lib/fusionSF-compressed.js:3110:105
respondToReadyState at http://pms03/mapguide312/fusion/lib/fusionSF-compressed.js:2061:35
onStateChange at http://pms03/mapguide312/fusion/lib/fusionSF-compressed.js:2058:426
Response:
{"FeatureInformation":{"FeatureSet":[{"@xmlns:xsi":["http://www.w3.org/2001/XMLSchema-instance"],"@xsi:noNamespaceSchemaLocation":["FeatureSet-1.0.0.xsd"],"Layer":[{"@id":["d696fc10-4f27-11ea-801a-00155d10e807"],"Class":[{"@id":["Schema1:vsz_Zupanija"],"ID":["AQAAAA=="]}]}]}],"Hyperlink":null,"InlineSelectionImage":null,"SelectedFeatures":null,"Tooltip":null}}
Stack Trace:
- ajaxException at
http://pms03/mapguide312/fusion/lib/fusionSF-compressed.js (line: 33)
- bind/< at http://pms03/mapguide312/fusion/lib/fusionSF-compressed.js
(line: 1174)
- dispatchException at
http://pms03/mapguide312/fusion/lib/fusionSF-compressed.js (line: 2061)
- respondToReadyState at
- onStateChange at
http://pms03/mapguide312/fusion/lib/fusionSF-compressed.js (line: 2058)
(line: 1174)
Source:
http://pms03/mapguide312/fusion/templates/mapguide/Vsz/index.html?ApplicationDefinition=Library://SSUZ%20VSZ/VSZ.ApplicationDefinition&locale=hr
It happens only when layers don't have visible properties in viewer turn on
in maestro.
If layer has visible properties turn on in maestro it doesn't give me fusion
error.
In version 2.6 if worked it just gave me the legend label in selection panel
with empty result.
Sent from: http://osgeo-org.1560.x6.nabble.com/MapGuide-Users-f4182607.html
