[Mapserver-dev] output format save
Sean Gillies sgillies at frii.com
Wed Jul 2 12:13:52 EDT 2003
On Wednesday, July 2, 2003, at 09:15  AM, Yewondwossen Assefa wrote:
> Hi There,
> We just realized the output formats are not written into the map file
> when It is saved. I realize that saving the imagetype is enough (to
> recreate the same mapfile) for default output formats, but we end up
> loosing some specific user defined format options.
>  I guess there are several ways to adress this :
>   - write only the current output format used in the map file
>   - write all the output formats
>   - write back only output formats that are user defined (loaded from
> map file or create by mapscript) . In trhis case we would also write
> current one if diffrent from the user defined.
> Maybe there are other ways. What are your take on this ?
> Later,
I prefer your third way.
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://www.frii.com/~sgillies
