[Mapserver-dev] Max number of layers craps out at about 295
Stephen Clark
stephen.clark at focus.ca
Wed Feb 11 18:27:25 EST 2004
This is a multi-part message in MIME format.
------=_NextPart_000_08F4_01C3F0B3.8D52EC60
Content-Type: multipart/alternative;
boundary="----=_NextPart_001_08F5_01C3F0B3.8D52EC60"
------=_NextPart_001_08F5_01C3F0B3.8D52EC60
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Hi all,
I am trying to get the max number of layers that MS will read from a =
*.map file to be 500 or more.
Once I exceed about 295 layers the MAP file will not be displayed.
The error I get is 'The Memory could not be "read".' with some hex codes =
displayed.
I have attached my "map.h" file as reference.
Is there some other file that have to modify to be able to increase the =
number of layers?
thanks
Stephen
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML xmlns=3D"http://www.w3.org/TR/REC-html40" xmlns:o =3D=20
"urn:schemas-microsoft-com:office:office" xmlns:w =3D=20
"urn:schemas-microsoft-com:office:word"><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3DWord.Document name=3DProgId>
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR>
<META content=3D"Microsoft Word 10" name=3DOriginator><LINK=20
href=3D"cid:filelist.xml at 01C3F0D6.7488DD20" rel=3DFile-List><!--[if gte =
mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:HyphenationZone>21</w:HyphenationZone>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]-->
<STYLE>@page Section1 {size: 612.0pt 792.0pt; margin: 70.85pt 3.0cm =
70.85pt 3.0cm; mso-header-margin: 35.4pt; mso-footer-margin: 35.4pt; =
mso-paper-source: 0; }
P.MsoNormal {
FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman"; =
mso-style-parent: ""; mso-pagination: widow-orphan; =
mso-fareast-font-family: "Times New Roman"
LI.MsoNormal {
DIV.MsoNormal {
A:link {
COLOR: blue; TEXT-DECORATION: underline; text-underline: single
SPAN.MsoHyperlink {
A:visited {
COLOR: purple; TEXT-DECORATION: underline; text-underline: single
SPAN.MsoHyperlinkFollowed {
SPAN.EstiloDeEmail17 {
COLOR: windowtext; FONT-FAMILY: Arial; mso-style-type: =
personal-compose; mso-style-noshow: yes; mso-ansi-font-size: 10.0pt; =
mso-bidi-font-size: 10.0pt; mso-ascii-font-family: Arial; =
mso-hansi-font-family: Arial; mso-bidi-font-family: Arial
SPAN.SpellE {
mso-style-name: ""; mso-spl-e: yes
SPAN.GramE {
mso-style-name: ""; mso-gram-e: yes
DIV.Section1 {
page: Section1
</STYLE>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Tabela normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
</style>
<![endif]--></HEAD>
<BODY lang=3DPT-BR style=3D"tab-interval: 35.4pt" vLink=3Dpurple =
link=3Dblue=20
bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Hi all,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>I am trying to get the max number of =
layers that MS=20
will read from a *.map file to be 500 or more.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Once I exceed about 295 layers the MAP =
file will=20
not be displayed.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>The error I get is 'The Memory could =
not be=20
"read".' with some hex codes displayed.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I have attached my "map.h" file as=20
reference.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Is there some other file that have to =
modify to be=20
able to increase the number of layers?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>thanks</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Stephen</FONT></DIV></BODY></HTML>
------=_NextPart_001_08F5_01C3F0B3.8D52EC60--
name="map.h"
Content-Disposition: attachment;
filename="map.h"
#ifndef MAP_H
#define MAP_H
/* $Id: map.h,v 1.255 2003/08/01 04:34:50 sdlime Exp $
** Main includes. If a particular header was needed by several .c files =
then
** I just put it here. What the hell, it works and it's all right here. =
-SDL-
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <math.h>
#if defined(_WIN32) && !defined(__CYGWIN__)
#include <direct.h>
#include <memory.h>
#include <malloc.h>
#else
#include <unistd.h>
#endif
#ifdef USE_MPATROL
#include "mpatrol.h"
#endif
#include "maperror.h"
#include "mapprimitive.h"
#include "mapshape.h"
#include "mapsymbol.h"
#include "maptree.h" // quadtree spatial index
#include "maphash.h"
#include "mapproject.h"
#include <gd.h>
#if defined USE_PDF
#include <pdflib.h>
#endif
#ifdef USE_MING_FLASH
#include "ming.h"
#endif
#include <sys/types.h> /* regular expression support */
#include <regex.h>
#ifdef USE_MING
#include "ming.h"
#endif
#ifdef __cplusplus
extern "C" {
#endif
// General defines, wrapable
#define MS_VERSION "4.0.1.1"
#define MS_TRUE 1 /* logical control variables */
#define MS_FALSE 0
#define MS_ON 1
#define MS_OFF 0
#define MS_DEFAULT 2
#define MS_EMBED 3
#define MS_DELETE 4
#define MS_YES 1
#define MS_NO 0
#define MS_SINGLE 0 /* modes for searching (spatial/database) */
#define MS_MULTIPLE 1
// General defines, not wrapable
#ifndef SWIG
#define MS_DEFAULT_MAPFILE_PATTERN "\\.map$"
#define MS_TEMPLATE_EXPR =
"\\.(jsp|asp|cfm|xml|wml|html|htm|shtml|phtml|php)$"
#define MS_INDEX_EXTENSION ".qix"
#define MS_QUERY_EXTENSION ".qy"
#define MS_DEG_TO_RAD .0174532925199432958
#define MS_RAD_TO_DEG 57.29577951
#define MS_RED 0
#define MS_GREEN 1
#define MS_BLUE 2
#define MS_MAXCOLORS 700 /* maximum nuumber of color calls in a map file =
??? */=20
#define MS_BUFFER_LENGTH 2048 /* maximum input line length */
#define MS_URL_LENGTH 1024
#define MS_MAXPATHLEN 1024
#define MS_MAXIMGSIZE 2048
#define MS_MAXCLASSES 700 /* maximum number of classes in a map file */
#define MS_MAXSTYLES 15
#define MS_MAXPROJARGS 20
#define MS_MAXLAYERS 700 /* maximum number of layers in a map file */
#define MS_MAXJOINS 15
#define MS_ITEMNAMELEN 32
#define MS_NAMELEN 32
#define MS_MINSYMBOLSIZE 1 // in pixels
#define MS_MAXSYMBOLSIZE 100
#define MS_URL 0 /* template types */
#define MS_FILE 1
#define MS_MINFONTSIZE 4
#define MS_MAXFONTSIZE 256
#define MS_LABELCACHEINITSIZE 100
#define MS_LABELCACHEINCREMENT 10
#define MS_RESULTCACHEINITSIZE 10
#define MS_RESULTCACHEINCREMENT 10
#define MS_FEATUREINITSIZE 10 /* how many points initially can a feature =
have */
#define MS_FEATUREINCREMENT 10
#define MS_EXPRESSION 2000
#define MS_REGEX 2001
#define MS_STRING 2002
#define MS_NUMBER 2003
#define MS_COMMENT 2004
// General macro definitions
#define MS_MIN(a,b) (((a)<(b))?(a):(b))
#define MS_MAX(a,b) (((a)>(b))?(a):(b))
#define MS_ABS(a) (((a)<0) ? -(a) : (a))
#define MS_SGN(a) (((a)<0) ? -1 : 1)
#define MS_NINT(x) ((x) >=3D 0.0 ? ((long) ((x)+.5)) : ((long) =
((x)-.5)))
#define MS_PEN_TRANSPARENT -1
#define MS_PEN_UNSET -4
#define MS_VALID_EXTENT(minx, miny, maxx, maxy) (((minx<maxx) && =
(miny<maxy))?MS_TRUE:MS_FALSE)
#define MS_INIT_COLOR(color,r,g,b) { (color).red =3D r; (color).green =
=3D g; (color).blue =3D b; (color).pen =3D MS_PEN_UNSET; }
#define MS_VALID_COLOR(color) (((color).red=3D=3D-1 || =
(color).green=3D=3D-1 || (color).blue=3D=3D-1)?MS_FALSE:MS_TRUE)
#define MS_TRANSPARENT_COLOR(color) (((color).red=3D=3D-255 || =
(color).green=3D=3D-255 || (color).blue=3D=3D-255)?MS_TRUE:MS_FALSE)
#define MS_COMPARE_COLORS(a,b) (((a).red!=3D(b).red || =
(a).green!=3D(b).green || (a).blue!=3D(b).blue)?MS_FALSE:MS_TRUE)
#define MS_IMAGE_MIME_TYPE(format) (format->mimetype ? format->mimetype =
: "unknown")
#define MS_IMAGE_EXTENSION(format) (format->extension ? =
format->extension : "unknown")
#define MS_DRIVER_GD(format) =
(strncasecmp((format)->driver,"gd/",3)=3D=3D0)
#define MS_DRIVER_SWF(format) =
(strncasecmp((format)->driver,"swf",3)=3D=3D0)
#define MS_DRIVER_GDAL(format) =
(strncasecmp((format)->driver,"gdal/",5)=3D=3D0)
#define MS_DRIVER_PDF(format) =
(strncasecmp((format)->driver,"pdf",3)=3D=3D0)
#define MS_DRIVER_IMAGEMAP(format) =
(strncasecmp((format)->driver,"imagemap",8)=3D=3D0)
#define MS_RENDER_WITH_GD 1
#define MS_RENDER_WITH_SWF 2
#define MS_RENDER_WITH_RAWDATA 3
#define MS_RENDER_WITH_PDF 4
#define MS_RENDER_WITH_IMAGEMAP 5
#define MS_RENDERER_GD(format) ((format)->renderer =3D=3D =
MS_RENDER_WITH_GD)
#define MS_RENDERER_SWF(format) ((format)->renderer =3D=3D =
MS_RENDER_WITH_SWF)
#define MS_RENDERER_RAWDATA(format) ((format)->renderer =3D=3D =
MS_RENDER_WITH_RAWDATA)
#define MS_RENDERER_PDF(format) ((format)->renderer =3D=3D =
MS_RENDER_WITH_PDF)
#define MS_RENDERER_IMAGEMAP(format) ((format)->renderer =3D=3D =
MS_RENDER_WITH_IMAGEMAP)
// ok, we'll switch to an UL cell model to make this work with WMS
#define MS_CELLSIZE(min,max,d) ((max - min)/d)
#define MS_MAP2IMAGE_X(x,minx,cx) (MS_NINT((x - minx)/cx))
#define MS_MAP2IMAGE_Y(y,maxy,cy) (MS_NINT((maxy - y)/cy))
#define MS_IMAGE2MAP_X(x,minx,cx) (minx + cx*x)
#define MS_IMAGE2MAP_Y(y,maxy,cy) (maxy - cy*y)
// For maplabel and mappdf
#define LINE_VERT_THRESHOLD .17 // max absolute value of cos of line =
angle, the closer to zero the more vertical the line must be
// For CARTO symbols
#define MS_PI 3.14159265358979323846
#define MS_PI2 1.57079632679489661923 // (MS_PI / 2)
#define MS_3PI2 4.71238898038468985769 // (3 * MS_PI2)
#define MS_2PI 6.28318530717958647693 // (2 * MS_PI)
#endif
// General enumerated types - needed by scripts
enum MS_FILE_TYPE {MS_FILE_MAP, MS_FILE_SYMBOL};
enum MS_UNITS {MS_INCHES, MS_FEET, MS_MILES, MS_METERS, MS_KILOMETERS, =
MS_DD, MS_PIXELS};
enum MS_SHAPE_TYPE {MS_SHAPE_POINT, MS_SHAPE_LINE, MS_SHAPE_POLYGON, =
MS_SHAPE_NULL};
enum MS_LAYER_TYPE {MS_LAYER_POINT, MS_LAYER_LINE, MS_LAYER_POLYGON, =
MS_LAYER_RASTER, MS_LAYER_ANNOTATION, MS_LAYER_QUERY, MS_LAYER_CIRCLE, =
MS_LAYER_GRATICULE};
enum MS_FONT_TYPE {MS_TRUETYPE, MS_BITMAP};
enum MS_LABEL_POSITIONS {MS_UL, MS_LR, MS_UR, MS_LL, MS_CR, MS_CL, =
MS_UC, MS_LC, MS_CC, MS_AUTO, MS_XY}; // arrangement matters for auto =
placement, don't change it
enum MS_BITMAP_FONT_SIZES {MS_TINY , MS_SMALL, MS_MEDIUM, MS_LARGE, =
MS_GIANT};
enum MS_QUERYMAP_STYLES {MS_NORMAL, MS_HILITE, MS_SELECTED};
enum MS_CONNECTION_TYPE {MS_INLINE, MS_SHAPEFILE, MS_TILED_SHAPEFILE, =
MS_SDE, MS_OGR, MS_UNUSED_1, MS_POSTGIS, MS_WMS, MS_ORACLESPATIAL, =
MS_WFS, MS_GRATICULE, MS_MYGIS };
enum MS_JOIN_CONNECTION_TYPE {MS_DB_XBASE, MS_DB_MYSQL, MS_DB_ORACLE, =
MS_DB_POSTGRES};
enum MS_JOIN_TYPE {MS_JOIN_ONE_TO_ONE, MS_JOIN_ONE_TO_MANY};
enum MS_CAPS_JOINS_AND_CORNERS {MS_CJC_NONE, MS_CJC_BEVEL, MS_CJC_BUTT, =
MS_CJC_MITER, MS_CJC_ROUND, MS_CJC_SQUARE, MS_CJC_TRIANGLE};=20
enum MS_RETURN_VALUE {MS_SUCCESS, MS_FAILURE, MS_DONE};
enum MS_IMAGEMODE { MS_IMAGEMODE_PC256, MS_IMAGEMODE_RGB, =
MS_IMAGEMODE_RGBA, MS_IMAGEMODE_INT16, MS_IMAGEMODE_FLOAT32 };
#define MS_FILE_DEFAULT MS_FILE_MAP =20
=20
// FONTSET OBJECT - used to hold aliases for TRUETYPE fonts
typedef struct {
#ifdef SWIG
%immutable;
#endif
char *filename;=20
int numfonts;
#ifdef SWIG
%mutable;
#endif
#ifndef SWIG
hashTableObj fonts;
struct map_obj *map;
#endif
} fontSetObj;
// FEATURE LIST OBJECT - for inline features, shape caches and queries
#ifndef SWIG
typedef struct listNode {
shapeObj shape;
struct listNode *next;
} featureListNodeObj;
typedef featureListNodeObj * featureListNodeObjPtr;
#endif
// COLOR OBJECT
typedef struct {
int pen;
int red;
int green;
int blue;
#if ALPHACOLOR_ENABLED
int alpha;
#endif
} colorObj;
#ifndef SWIG
// PALETTE OBJECT - used to hold colors while a map file is read
typedef struct {
colorObj colors[MS_MAXCOLORS-1];
int colorvalue[MS_MAXCOLORS-1];
int numcolors;
} paletteObj;
#endif
// EXPRESSION OBJECT
#ifndef SWIG
typedef struct {
char *string;
int type;
// logical expression options
char **items;
int *indexes;
int numitems;
// regular expression options
regex_t regex; // compiled regular expression to be matched
int compiled;
} expressionObj;
#endif
#ifndef SWIG
// JOIN OBJECT - simple way to access other XBase files, one-to-one or =
one-to-many supported
typedef struct {
char *name;
char **items, **values; // items/values (process 1 record at a time)
int numitems;
char *table;
char *from, *to; // item names
void *joininfo; // vendor specific (i.e. XBase, MySQL, etc.) stuff to =
allow for persistant access
=20
char *header, *footer;
#ifndef __cplusplus
char *template;
#else
char *_template;
#endif
enum MS_JOIN_TYPE type;
char *connection;
enum MS_JOIN_CONNECTION_TYPE connectiontype;
} joinObj;
#endif
// OUTPUT FORMAT OBJECT - see mapoutput.c for most related code.
typedef struct {
char *name;
char *mimetype;
char *driver;
char *extension;
int renderer; // MS_RENDER_WITH_*
int imagemode; // MS_IMAGEMODE_* value.
int transparent;
int numformatoptions;
char **formatoptions;
int refcount;
int inmapfile; //boolean value for writing
} outputFormatObj;
// The following is used for "don't care" values in transparent, =
interlace and
// imagequality values.=20
#define MS_NOOVERRIDE -1111=20
// QUERY MAP OBJECT - used to visualize query results
typedef struct {
int height, width;
int status;
int style; /* HILITE, SELECTED or NORMAL */
colorObj color;
} queryMapObj;
// LABEL OBJECT - parameters needed to annotate a layer, legend or =
scalebar
typedef struct {
char *font;
enum MS_FONT_TYPE type;
colorObj color;
colorObj outlinecolor;
colorObj shadowcolor;
int shadowsizex, shadowsizey;
colorObj backgroundcolor;
colorObj backgroundshadowcolor;
int backgroundshadowsizex, backgroundshadowsizey;
int size;
int sizescaled;
int minsize, maxsize;
int position;
int offsetx, offsety;
double angle;
int autoangle; // true or false
int buffer; /* space to reserve around a label */
int antialias;
char wrap;
int minfeaturesize; /* minimum feature size (in pixels) to label */
int autominfeaturesize; // true or false
int mindistance;
int partials; /* can labels run of an image */
int force; // labels *must* be drawn
} labelObj;
// WEB OBJECT - holds parameters for a mapserver/mapscript interface
typedef struct {
char *log;
char *imagepath, *imageurl;
#ifndef __cplusplus
char *template;
#else
char *_template;
#endif
char *empty, *error; /* error handling */
rectObj extent; /* clipping extent */
double minscale, maxscale;
char *mintemplate, *maxtemplate;
#ifndef SWIG
hashTableObj metadata;
#endif
} webObj;
// STYLE OBJECT - holds parameters for symbolization, multiple styles =
may be applied within a classObj
typedef struct {
colorObj color;
int symbol;
char *symbolname;
int size;
int sizescaled; // may not need this
int offsetx, offsety; // for shadows, hollow symbols, etc...
int antialias;
} styleObj;
// CLASS OBJECT - basic symbolization and classification information
typedef struct class_obj{
#ifndef SWIG
expressionObj expression; // the expression to be matched
#endif
int status;
styleObj *styles;
int numstyles;
labelObj label;
char *name; // should be unique within a layer
char *title; // used for legend labeling
#ifndef SWIG
expressionObj text;
#endif
#ifndef __cplusplus
char *template;
#else
char *_template;
#endif
int type;
#ifndef SWIG
#endif
struct layer_obj *layer;
int debug;
char *keyimage;
} classObj;
// LABELCACHE OBJECTS - structures to implement label caching and =
collision avoidance etc
// Note: These are scriptable, but are read only.
#ifdef SWIG
%immutable;
#endif
typedef struct {
char *string;
double featuresize;
styleObj *styles; // copied from the classObj, only present if there =
is a marker to be drawn
int numstyles;
labelObj label; // copied from the classObj
int layerindex; // indexes
int classindex;
int tileindex;
int shapeindex;
pointObj point; // label point
shapeObj *poly; // label bounding box
int status; // has this label been drawn or not
} labelCacheMemberObj;
typedef struct {
int id; // corresponding label
shapeObj *poly; // marker bounding box (POINT layers only)
} markerCacheMemberObj;
typedef struct {
labelCacheMemberObj *labels;
int numlabels;
int cachesize;
markerCacheMemberObj *markers;
int nummarkers;
int markercachesize;
} labelCacheObj;
typedef struct {
long shapeindex;
int tileindex;
char classindex;
} resultCacheMemberObj;
#ifdef SWIG
%mutable;
#endif
typedef struct {
#ifndef SWIG
resultCacheMemberObj *results;
int cachesize;
#endif
#ifdef SWIG
%immutable;
#endif
int numresults;
rectObj bounds;
#ifdef SWIG
%mutable;
#endif
} resultCacheObj;
// SYMBOLSET OBJECT
typedef struct {
char *filename;
int imagecachesize;
#ifdef SWIG
%immutable;
#endif // SWIG
int numsymbols;
#ifdef SWIG
%mutable;
#endif // SWIG
symbolObj symbol[MS_MAXSYMBOLS];
#ifndef SWIG
fontSetObj *fontset; // a pointer to the main mapObj version
struct imageCacheObj *imagecache;
#endif // SWIG
} symbolSetObj;
// REFERENCE MAP OBJECT
typedef struct {
rectObj extent;
int height, width;
colorObj color;
char *image;
int status;
int marker;
char *markername;
int markersize;
int minboxsize;
int maxboxsize;
} referenceMapObj;
// SCALEBAR OBJECT
typedef struct {
colorObj imagecolor;
int height, width;
int style;
int intervals;
labelObj label;
colorObj color;
int units;
int status; // ON, OFF or EMBED
int position; // for embeded scalebars
int transparent;
int interlace;
int postlabelcache;
} scalebarObj;
// LEGEND OBJECT
typedef struct {
labelObj label;
int keysizex, keysizey;
int keyspacingx, keyspacingy;
colorObj outlinecolor; // Color of outline of box, -1 for no outline
int height, width;
int position; // for embeded legends
int transparent;
int interlace;
int postlabelcache;
#ifndef __cplusplus
char *template;
#else
char *_template;
#endif
} legendObj;
typedef struct
double dwhichlatitude;
double dwhichlongitude;
double dstartlatitude;
double dstartlongitude;
double dendlatitude;
double dendlongitude;
double dincrementlatitude;
double dincrementlongitude;
double minarcs;
double maxarcs;
double minincrement;
double maxincrement;
double minsubdivides;
double maxsubdivides;
int bvertical;
int blabelaxes;
int ilabelstate;
int ilabeltype;
rectObj extent;
lineObj *pboundinglines;
pointObj *pboundingpoints;
char *labelformat;
} graticuleObj;
// LAYER OBJECT - basic unit of a map
typedef struct layer_obj {
int index;
char *classitem; // .DBF item to be used for symbol lookup
int classitemindex;
#ifndef SWIG
#ifndef __cplusplus
classObj *class; // always at least 1 class
#else
classObj *_class;
#endif
#endif
#ifdef SWIG
%immutable;
#endif
int numclasses;
#ifdef SWIG
%mutable;
#endif
char *header, *footer; // only used with multi result queries
#ifndef __cplusplus
char *template; // global template, used across all classes
#else
char *_template;
#endif
resultCacheObj *resultcache; // holds the results of a query against =
this layer
char *group; // shouldn't be unique it's supposed to be a group right?
int status; // on or off
char *data; // filename, can be relative or full path
enum MS_LAYER_TYPE type;
int annotate; // boolean flag for annotation
double tolerance; // search buffer for point and line queries (in =
toleranceunits)
int toleranceunits;
double symbolscale; // scale at which symbols are default size
double scalefactor; // computed, not set
double labelminscale, labelmaxscale;
int sizeunits; // applies to all classes
int maxfeatures;
colorObj offsite; // transparent pixel value for raster images
int transform; // does this layer have to be transformed to file =
coordinates
int labelcache, postlabelcache; // on or off
char *labelitem, *labelsizeitem, *labelangleitem;
int labelitemindex, labelsizeitemindex, labelangleitemindex;
char *tileitem;
int tileitemindex;
char *tileindex; // layer index file for tiling support
#ifndef SWIG
projectionObj projection; // projection information for the layer
#endif
int project; // boolean variable, do we need to project this layer or =
not
int units; // units of the projection
#ifndef SWIG
featureListNodeObjPtr features; // linked list so we don't need a =
counter
featureListNodeObjPtr currentfeature; // pointer to the current =
feature
#endif
char *connection;
enum MS_CONNECTION_TYPE connectiontype;
struct layer_obj *sameconnection;
=20
#ifndef SWIG
// SDL has converted OracleSpatial, SDE, Graticules, MyGIS
void *layerinfo; // all connection types should use this generic =
pointer to a vendor specific structure
void *ogrlayerinfo; // For OGR layers, will contain a msOGRLayerInfo =
struct
void *wfslayerinfo; // For WFS layers, will contain a msWFSLayerInfo =
struct=20
#endif
// attribute/classification handling components
char **items;
int numitems;
#ifndef SWIG
void *iteminfo; // connection specific information necessary to =
retrieve values
#endif
#ifndef SWIG
expressionObj filter; // connection specific attribute filter
#endif
char *filteritem;
int filteritemindex;
char *styleitem; // item to be used for style lookup - can also be =
'AUTO'
int styleitemindex;
char *requires; // context expressions, simple enough to not use =
expressionObj
char *labelrequires;
#ifndef SWIG
#endif
=20
int transparency; // transparency value 0-100=20
int dump;
int debug;
#ifndef SWIG
int num_processing;
char **processing;
#endif
joinObj *joins;
int numjoins;
} layerObj;
// MAP OBJECT - encompasses everything used in an Internet mapping =
application
typedef struct map_obj{ /* structure for a map */
char *name; /* small identifier for naming etc. */
int status; /* is map creation on or off */
int height, width;
layerObj *layers;
#ifdef SWIG
%immutable;
#endif
int numlayers; /* number of layers in mapfile */
#ifdef SWIG
%mutable;
#endif
symbolSetObj symbolset;
fontSetObj fontset;
labelCacheObj labelcache; /* we need this here so multiple feature =
processors can access it */
int transparent; // TODO - Deprecated
int interlace; // TODO - Deprecated
int imagequality; // TODO - Deprecated
rectObj extent; /* map extent array */
double cellsize; /* in map units */
enum MS_UNITS units; /* units of the projection */
double scale; /* scale of the output image */
double resolution;
char *shapepath; /* where are the shape files located */
char *mappath; /* path of the mapfile, all path are relative to this =
path */
paletteObj palette; /* holds a map palette */
colorObj imagecolor; /* holds the initial image color value */
int numoutputformats;
outputFormatObj **outputformatlist;
outputFormatObj *outputformat;
#ifdef SWIG
%immutable;
#endif
char *imagetype; /* name of current outputformat */
#ifdef SWIG
%mutable;
#endif // SWIG
#ifdef SWIG
%immutable;
#endif
#ifndef SWIG
projectionObj projection; /* projection information for output map */
projectionObj latlon; /* geographic projection definition */
#endif
referenceMapObj reference;
scalebarObj scalebar;
legendObj legend;
queryMapObj querymap;
webObj web;
int *layerorder;
int debug; =20
char *datapattern, *templatepattern; =20
} mapObj;
//SWF Object structure
typedef struct {
mapObj *map;
SWFMovie sMainMovie;
int nLayerMovies;
SWFMovie *pasMovies;
int nCurrentMovie;
int nCurrentLayerIdx;
int nCurrentShapeIdx;
void *imagetmp; //used when the output format is SINGLE=20
//(one movie for the whole map) =20
} SWFObj;
#endif
//PDF Object structure
#ifdef USE_PDF
typedef struct {
mapObj *map;
PDF *pdf;
void *imagetmp; //used when the FORMATOPTION =
"OUTPUT_TYPE=3DRASTER"
} PDFObj;=20
#endif
// IMAGE OBJECT - a wrapper for GD images
typedef struct {
#ifdef SWIG
%immutable;
#endif
int width, height;
#ifdef SWIG
%mutable;
#endif
outputFormatObj *format;
int renderer;
int size;
#ifndef SWIG
union {
gdImagePtr gd;
SWFObj *swf;
#endif
#ifdef USE_PDF
PDFObj *pdf;
#endif
char *imagemap;
short *raw_16bit;
float *raw_float;
} img;
#endif
} imageObj;
// Function prototypes, wrapable
int msSaveImage(mapObj *map, imageObj *img, char *filename);
void msFreeImage(imageObj *img);
// Function prototypes, not wrapable
#ifndef SWIG
int msDrawSDELayer(mapObj *map, layerObj *layer, gdImagePtr img); /* in =
mapsde.c */
** helper functions not part of the general API but needed in
** a few other places (like mapscript)... found in mapfile.c
char *getString(void);
int getDouble(double *d);
int getInteger(int *i);
int getSymbol(int n, ...);
int getCharacter(char *c);
void initSymbol(symbolObj *s);
int initMap(mapObj *map);
int initLayer(layerObj *layer, mapObj *map);
int initClass(classObj *_class);
void initLabel(labelObj *label);
void resetClassStyle(classObj *_class);
int initStyle(styleObj *style);
void initReferenceMap(referenceMapObj *ref);
void initScalebar(scalebarObj *scalebar);
void initGrid( graticuleObj *pGraticule );
featureListNodeObjPtr insertFeatureList(featureListNodeObjPtr *list, =
shapeObj *shape);
void freeFeatureList(featureListNodeObjPtr list);
int msLoadProjectionString(projectionObj *p, char *value);
int loadExpressionString(expressionObj *exp, char *value);
void freeExpression(expressionObj *exp);
int getClassIndex(layerObj *layer, char *str);
* Functions used to copy maps
void copyProperty(void *dst, void *src, int size);
char *copyStringProperty(char **dst, char *src);
int msCopyMap(mapObj *, mapObj *);
int msCopyLayer(layerObj *, layerObj *);
int labelInImage(int width, int height, shapeObj *lpoly, int buffer);
int intersectLabelPolygons(shapeObj *p1, shapeObj *p2);
pointObj get_metrics(pointObj *p, int position, rectObj rect, int ox, =
int oy, double angle, int buffer, shapeObj *poly);
double dist(pointObj a, pointObj b);
=20
** Main API Functions
=20
int msGetLayerIndex(mapObj *map, char *name); // in mapfile.c
int msGetSymbolIndex(symbolSetObj *set, char *name);
mapObj *msLoadMap(char *filename, char *new_mappath);
int msSaveMap(mapObj *map, char *filename);
void msFreeMap(mapObj *map);
void msFreeCharArray(char **array, int num_items);
int msLoadMapString(mapObj *map, char *object, char *value);
mapObj *msNewMapObj();
int msEvalRegex(char *e, char *s);
void msFree(void *p);
char **msTokenizeMap(char *filename, int *numtokens);
int msInitLabelCache(labelCacheObj *cache);
int msFreeLabelCache(labelCacheObj *cache);
int msCheckConnection(layerObj * layer); // connection pooling functions =
(mapfile.c)
void msCloseConnections(mapObj *map);=20
#if defined USE_PDF
PDF *msDrawMapPDF(mapObj *map, PDF *pdf, hashTableObj fontHash); // =
mappdf.c
#endif
void msCleanup();
void msGDALCleanup();
void msGDALInitialize();
=20
imageObj *msDrawScalebar(mapObj *map); // in mapscale.c
int msCalculateScale(rectObj extent, int units, int width, int height, =
double resolution, double *scale);
double msInchesPerUnit(int units, double center_lat);
int msEmbedScalebar(mapObj *map, gdImagePtr img);
int msPointInRect(pointObj *p, rectObj *rect); // in mapsearch.c
int msRectOverlap(rectObj *a, rectObj *b);
int msRectContained(rectObj *a, rectObj *b);
void msMergeRect(rectObj *a, rectObj *b);
double msDistancePointToPoint(pointObj *a, pointObj *b);
double msDistancePointToSegment(pointObj *p, pointObj *a, pointObj *b);
double msDistancePointToShape(pointObj *p, shapeObj *shape);
double msDistanceSegmentToSegment(pointObj *pa, pointObj *pb, pointObj =
*pc, pointObj *pd);
double msDistanceShapeToShape(shapeObj *shape1, shapeObj *shape2);
int msIntersectSegments(pointObj *a, pointObj *b, pointObj *c, pointObj =
*d);
int msPointInPolygon(pointObj *p, lineObj *c);
int msIntersectMultipointPolygon(multipointObj *points, shapeObj =
*polygon);
int msIntersectPointPolygon(pointObj *p, shapeObj *polygon);
int msIntersectPolylinePolygon(shapeObj *line, shapeObj *poly);
int msIntersectPolygons(shapeObj *p1, shapeObj *p2);
int msIntersectPolylines(shapeObj *line1, shapeObj *line2);
int msSaveQuery(mapObj *map, char *filename); // in mapquery.c
int msLoadQuery(mapObj *map, char *filename);
int msQueryByIndex(mapObj *map, int qlayer, int tileindex, int =
shapeindex);
int msQueryByIndexAdd(mapObj *map, int qlayer, int tileindex, int =
shapeindex);
int msQueryByAttributes(mapObj *map, int qlayer, char *qitem, char =
*qstring, int mode);
int msQueryByPoint(mapObj *map, int qlayer, int mode, pointObj p, double =
buffer);
int msQueryByRect(mapObj *map, int qlayer, rectObj rect);
int msQueryByFeatures(mapObj *map, int qlayer, int slayer);
int msQueryByShape(mapObj *map, int qlayer, shapeObj *selectshape);
int msGetQueryResultBounds(mapObj *map, rectObj *bounds);
int msIsLayerQueryable(layerObj *lp);
void msQueryFree(mapObj *map, int qlayer);
void trimBlanks(char *string); // in mapstring.c
char *chop(char *string);
void trimEOL(char *string);
char *gsub(char *str, const char *old, const char *sznew);
char *stripPath(char *fn);
char *getPath(char *fn);
char *msBuildPath(char *pszReturnPath, char *abs_path, char *path);
char *msBuildPath3(char *pszReturnPath,char *abs_path,char *path1,char =
*path2);
char *msTryBuildPath(char *szReturnPath, char *abs_path, char *path);
char **split(const char *string, char cd, int *num_tokens);
int countChars(char *str, char ch);
char *long2string(long value);
char *double2string(double value);
char *msEncodeUrl(const char*);
char *msEncodeHTMLEntities(const char *string);
void msDecodeHTMLEntities(const char *string);
char *strcatalloc(char *pszDest, char *pszSrc);
#ifdef NEED_STRDUP
char *strdup(char *s);
#endif
#ifdef NEED_STRNCASECMP
int strncasecmp(char *s1, char *s2, int len);
#endif
#ifdef NEED_STRCASECMP
int strcasecmp(char *s1, char *s2);
#endif
int msLoadSymbolSet(symbolSetObj *symbolset, mapObj *map); // in =
mapsymbol.c
void msInitSymbolSet(symbolSetObj *symbolset);
int msAddImageSymbol(symbolSetObj *symbolset, char *filename);
void msFreeSymbolSet(symbolSetObj *symbolset);
int msGetMarkerSize(symbolSetObj *symbolset, styleObj *style, int =
*width, int *height, double scalefactor);
int msGetCharacterSize(char *character, int size, char *font, rectObj =
*rect);
void freeImageCache(struct imageCacheObj *ic);
imageObj *msDrawLegend(mapObj *map); // in maplegend.c
int msEmbedLegend(mapObj *map, gdImagePtr img);
int msDrawLegendIcon(mapObj* map, layerObj* lp, classObj* myClass, int =
width, int height, gdImagePtr img, int dstX, int dstY);
imageObj *msCreateLegendIcon(mapObj* map, layerObj* lp, classObj* =
myClass, int width, int height);
=20
int msLoadFontSet(fontSetObj *fontSet, mapObj *map); // in maplabel.c
int msInitFontSet(fontSetObj *fontset);
int msFreeFontSet(fontSetObj *fontset);
int msGetLabelSize(char *string, labelObj *label, rectObj *rect, =
fontSetObj *fontSet, double scalefactor);
int msAddLabel(mapObj *map, int layerindex, int classindex, int =
shapeindex, int tileindex, pointObj *point, char *string, double =
featuresize);
gdFontPtr msGetBitmapFont(int size);
int msImageTruetypePolyline(symbolSetObj *symbolset, gdImagePtr img, =
shapeObj *p, styleObj *style, double scalefactor);
int msImageTruetypeArrow(symbolSetObj *symbolset, gdImagePtr img, =
void msFreeShape(shapeObj *shape); // in mapprimative.c
void msInitShape(shapeObj *shape);
int msCopyShape(shapeObj *from, shapeObj *to);
void msComputeBounds(shapeObj *shape);
void msRectToPolygon(rectObj rect, shapeObj *poly);
void msClipPolylineRect(shapeObj *shape, rectObj rect);
void msClipPolygonRect(shapeObj *shape, rectObj rect);
void msTransformShape(shapeObj *shape, rectObj extent, double cellsize, =
imageObj *image);
void msTransformShapeToPixel(shapeObj *shape, rectObj extent, double =
cellsize);
void msTransformPixelToShape(shapeObj *shape, rectObj extent, double =
cellsize);
void msImageCartographicPolyline(gdImagePtr im, shapeObj *p, styleObj =
*style, symbolObj *symbol, int c, double size, double scalefactor);
int msPolylineLabelPoint(shapeObj *p, pointObj *lp, int min_length, =
double *angle, double *length);
int msPolygonLabelPoint(shapeObj *p, pointObj *lp, int min_dimension);
int msAddLine(shapeObj *p, lineObj *new_line);
int msDrawRasterLayer(mapObj *map, layerObj *layer, imageObj *image); // =
in mapraster.c
imageObj *msDrawReferenceMap(mapObj *map);
size_t msGetBitArraySize(int numbits); // in mapbits.c
char *msAllocBitArray(int numbits);
int msGetBit(char *array, int index);
void msSetBit(char *array, int index, int value);
void msFlipBit(char *array, int index);
int msLayerOpen(layerObj *layer); // in maplayer.c
void msLayerClose(layerObj *layer);
int msLayerWhichShapes(layerObj *layer, rectObj rect);
int msLayerWhichItems(layerObj *layer, int classify, int annotate, char =
*metadata);
int msLayerNextShape(layerObj *layer, shapeObj *shape);
int msLayerGetItems(layerObj *layer);
int msLayerSetItems(layerObj *layer, char **items, int numitems);
int msLayerGetShape(layerObj *layer, shapeObj *shape, int tile, long =
record);
int msLayerGetExtent(layerObj *layer, rectObj *extent);
int msLayerGetAutoStyle(mapObj *map, layerObj *layer, classObj *c, int =
tile, long record);
int msTiledSHPOpenFile(layerObj *layer); // in mapshape.c
int msTiledSHPWhichShapes(layerObj *layer, rectObj rect);
int msTiledSHPNextShape(layerObj *layer, shapeObj *shape);
int msTiledSHPGetShape(layerObj *layer, shapeObj *shape, int tile, long =
record);
void msTiledSHPClose(layerObj *layer);
int msTiledSHPLayerGetItems(layerObj *layer);
int msTiledSHPLayerInitItemInfo(layerObj *layer);
int msTiledSHPLayerGetExtent(layerObj *layer, rectObj *extent);
int msOGRLayerOpen(layerObj *layer, const char *pszOverrideConnection); =
// in mapogr.cpp
int msOGRLayerClose(layerObj *layer);
int msOGRLayerWhichShapes(layerObj *layer, rectObj rect);
int msOGRLayerNextShape(layerObj *layer, shapeObj *shape);
int msOGRLayerGetItems(layerObj *layer);
int msOGRLayerInitItemInfo(layerObj *layer);
void msOGRLayerFreeItemInfo(layerObj *layer);
int msOGRLayerGetShape(layerObj *layer, shapeObj *shape, int tile, long =
record);
int msOGRLayerGetExtent(layerObj *layer, rectObj *extent);
int msOGRLayerGetAutoStyle(mapObj *map, layerObj *layer, classObj *c, =
int tile, long record);
int msPOSTGISLayerOpen(layerObj *layer); // in mappostgis.c
void msPOSTGISLayerFreeItemInfo(layerObj *layer);
int msPOSTGISLayerInitItemInfo(layerObj *layer);
int msPOSTGISLayerWhichShapes(layerObj *layer, rectObj rect);
int msPOSTGISLayerClose(layerObj *layer);
int msPOSTGISLayerNextShape(layerObj *layer, shapeObj *shape);
int msPOSTGISLayerGetShape(layerObj *layer, shapeObj *shape, long =
record);
int msPOSTGISLayerGetExtent(layerObj *layer, rectObj *extent);
int msPOSTGISLayerGetShapeRandom(layerObj *layer, shapeObj *shape, long =
*record);
int msPOSTGISLayerGetItems(layerObj *layer);
int msMYGISLayerOpen(layerObj *layer); // in mapmygis.c
void msMYGISLayerFreeItemInfo(layerObj *layer);
int msMYGISLayerInitItemInfo(layerObj *layer);
int msMYGISLayerWhichShapes(layerObj *layer, rectObj rect);
int msMYGISLayerClose(layerObj *layer);
int msMYGISLayerNextShape(layerObj *layer, shapeObj *shape);
int msMYGISLayerGetShape(layerObj *layer, shapeObj *shape, long record);
int msMYGISLayerGetExtent(layerObj *layer, rectObj *extent);
int msMYGISLayerGetShapeRandom(layerObj *layer, shapeObj *shape, long =
*record);
int msMYGISLayerGetItems(layerObj *layer);
int msSDELayerOpen(layerObj *layer); // in mapsde.c
void msSDELayerClose(layerObj *layer);
int msSDELayerWhichShapes(layerObj *layer, rectObj rect);
int msSDELayerNextShape(layerObj *layer, shapeObj *shape);
int msSDELayerGetItems(layerObj *layer);
int msSDELayerGetShape(layerObj *layer, shapeObj *shape, long record);
int msSDELayerGetExtent(layerObj *layer, rectObj *extent);
int msSDELayerInitItemInfo(layerObj *layer);
void msSDELayerFreeItemInfo(layerObj *layer);
char *msSDELayerGetSpatialColumn(layerObj *layer);
char *msSDELayerGetRowIDColumn(void);
int msOracleSpatialLayerOpen(layerObj *layer);
int msOracleSpatialLayerClose(layerObj *layer);
int msOracleSpatialLayerWhichShapes(layerObj *layer, rectObj rect);
int msOracleSpatialLayerNextShape(layerObj *layer, shapeObj *shape);
int msOracleSpatialLayerGetItems(layerObj *layer);
int msOracleSpatialLayerGetShape(layerObj *layer, shapeObj *shape, long =
record);
int msOracleSpatialLayerGetExtent(layerObj *layer, rectObj *extent);
int msOracleSpatialLayerInitItemInfo(layerObj *layer);
void msOracleSpatialLayerFreeItemInfo(layerObj *layer);
int msOracleSpatialLayerGetAutoStyle(mapObj *map, layerObj *layer, =
classObj *c, int tile, long record); =20
int msGraticuleLayerOpen(layerObj *layer); // in mapGraticule.cpp
int msGraticuleLayerClose(layerObj *layer);
int msGraticuleLayerWhichShapes(layerObj *layer, rectObj rect);
int msGraticuleLayerNextShape(layerObj *layer, shapeObj *shape);
int msGraticuleLayerGetItems(layerObj *layer);
int msGraticuleLayerInitItemInfo(layerObj *layer);
void msGraticuleLayerFreeItemInfo(layerObj *layer);
int msGraticuleLayerGetShape(layerObj *layer, shapeObj *shape, int tile, =
long record);
int msGraticuleLayerGetExtent(layerObj *layer, rectObj *extent);
int msGraticuleLayerGetAutoStyle(mapObj *map, layerObj *layer, classObj =
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D */
/* Prototypes for functions in mapdraw.c =
void msClearLayerPenValues(layerObj *layer);
void msClearScalebarPenValues(scalebarObj *scalebar);
void msClearLegendPenValues(legendObj *legend);
void msClearReferenceMapPenValues(referenceMapObj *referencemap);
void msClearQueryMapPenValues(queryMapObj *querymap);
void msClearPenValues(mapObj *map);
imageObj *msDrawMap(mapObj *map);
imageObj *msDrawQueryMap(mapObj *map);
int msLayerIsVisible(mapObj *map, layerObj *layer);
int msDrawLayer(mapObj *map, layerObj *layer, imageObj *image);
int msDrawVectorLayer(mapObj *map, layerObj *layer, imageObj *image);
int msDrawQueryLayer(mapObj *map, layerObj *layer, imageObj *image);
int msDrawWMSLayer(mapObj *map, layerObj *layer, imageObj *image);
int msDrawWFSLayer(mapObj *map, layerObj *layer, imageObj *image);
int msDrawShape(mapObj *map, layerObj *layer, shapeObj *shape, imageObj =
*image, int style);
int msDrawPoint(mapObj *map, layerObj *layer, pointObj *point, imageObj =
*image, int classindex, char *labeltext);
void msCircleDrawLineSymbol(symbolSetObj *symbolset, imageObj *image, =
pointObj *p, double r, styleObj *style, double scalefactor);
void msCircleDrawShadeSymbol(symbolSetObj *symbolset, imageObj *image, =
void msDrawMarkerSymbol(symbolSetObj *symbolset,imageObj *image, =
pointObj *p, styleObj *style, double scalefactor);
void msDrawLineSymbol(symbolSetObj *symbolset, imageObj *image, shapeObj =
void msDrawShadeSymbol(symbolSetObj *symbolset, imageObj *image, =
int msDrawLabel(imageObj *image, pointObj labelPnt, char *string, =
labelObj *label, fontSetObj *fontset, double scalefactor);
int msDrawText(imageObj *image, pointObj labelPnt, char *string, =
int msDrawLabelCache(imageObj *image, mapObj *map);
void msImageStartLayer(mapObj *map, layerObj *layer, imageObj *image);
void msImageEndLayer(mapObj *map, layerObj *layer, imageObj *image);
void msDrawStartShape(mapObj *map, layerObj *layer, imageObj *image, =
shapeObj *shape);
void msDrawEndShape(mapObj *map, layerObj *layer, imageObj *image, =
shapeObj *shape);
/* End of Prototypes for functions in mapdraw.c =
/* Prototypes for functions in mapimagemap.c =
imageObj *msImageCreateIM(int width, int height, outputFormatObj =
*format,
char *imagepath, char *imageurl);
imageObj *msImageLoadIM( const char *filename );
void msImageInitIM( imageObj *image );
void msImageStartLayerIM(mapObj *map, layerObj *layer, imageObj *image);
int msSaveImageIM(imageObj* img, char *filename, outputFormatObj =
*format);
int msSaveImageIM_LL(imageObj* img, char *filename, int type,
int transparent, int interlace, int quality);
void msFreeImagexsIM(imageObj* img);
void msFreeImageIM(imageObj* img);
void msCircleDrawLineSymbolIM(symbolSetObj *symbolset, imageObj* img, =
void msCircleDrawShadeSymbolIM(symbolSetObj *symbolset, imageObj* img, =
void msDrawMarkerSymbolIM(symbolSetObj *symbolset, imageObj* img, =
void msDrawLineSymbolIM(symbolSetObj *symbolset, imageObj* img, shapeObj =
void msDrawShadeSymbolIM(symbolSetObj *symbolset, imageObj* img, =
int msDrawTextIM(imageObj* img, pointObj labelPnt, char *string, =
int msDrawLabelCacheIM(imageObj* img, mapObj *map);
/* End of Prototypes for functions in mapimagemap.c =
/* Prototypes for functions in mapgd.c =
imageObj *msImageCreateGD(int width, int height, outputFormatObj =
*format,
imageObj *msImageLoadGD( const char *filename );
void msImageInitGD( imageObj *image, colorObj *background );
int msImageSetPenGD(gdImagePtr img, colorObj *color);
#define RESOLVE_PEN_GD(img,color) { if( (color).pen =3D=3D MS_PEN_UNSET =
) msImageSetPenGD( img, &(color) ); }
int msSaveImageGD(gdImagePtr img, char *filename, outputFormatObj =
*format);
int msSaveImageGD_LL(gdImagePtr img, char *filename, int type,
void msFreeImageGD(gdImagePtr img);
void msCircleDrawLineSymbolGD(symbolSetObj *symbolset, gdImagePtr img, =
void msCircleDrawShadeSymbolGD(symbolSetObj *symbolset, gdImagePtr img, =
void msDrawMarkerSymbolGD(symbolSetObj *symbolset, gdImagePtr img, =
void msDrawLineSymbolGD(symbolSetObj *symbolset, gdImagePtr img, =
void msDrawShadeSymbolGD(symbolSetObj *symbolset, gdImagePtr img, =
int msDrawTextGD(gdImagePtr img, pointObj labelPnt, char *string, =
int msDrawLabelCacheGD(gdImagePtr img, mapObj *map);
void msImageCopyMerge (gdImagePtr dst, gdImagePtr src,=20
int dstX, int dstY, int srcX, int srcY, int w, =
int h,
int pct);
// various JOIN functions (in mapjoin.c)
int msJoinConnect(layerObj *layer, joinObj *join);
int msJoinPrepare(joinObj *join, shapeObj *shape);
int msJoinNext(joinObj *join);
int msJoinClose(joinObj *join);
int msDBFJoinConnect(layerObj *layer, joinObj *join);
int msDBFJoinPrepare(joinObj *join, shapeObj *shape);
int msDBFJoinNext(joinObj *join);
int msDBFJoinClose(joinObj *join);
int msDBFJoinTable(layerObj *layer, joinObj *join, shapeObj *shape);
//in mapraster.c
int msDrawRasterLayerLow(mapObj *map, layerObj *layer, imageObj *image);
int msAddColorGD(mapObj *map, gdImagePtr img, int cmt, int r, int g, int =
b);
int msGetClass(layerObj *layer, colorObj *color);
//in mapdrawgdal.c
int msDrawRasterLayerGDAL(mapObj *map, layerObj *layer, imageObj *image, =
void *hDSVoid );
/* End of prototypes for functions in mapgd.c =
/* Prototypes for functions in maputil.c =
// For mappdf
int getRgbColor(mapObj *map,int i,int *r,int *g,int *b); // maputil.c
int msEvalContext(mapObj *map, char *context);
int msEvalExpression(expressionObj *expression, int itemindex, char =
**items,=20
int numitems);
int msShapeGetClass(layerObj *layer, shapeObj *shape, double scale);
char *msShapeGetAnnotation(layerObj *layer, shapeObj *shape);
int msAdjustImage(rectObj rect, int *width, int *height);
double msAdjustExtent(rectObj *rect, int width, int height);
int msConstrainExtent(rectObj *bounds, rectObj *rect, double overlay);
int *msGetLayersIndexByGroup(mapObj *map, char *groupname, int *nCount);
//Functions to chnage the drawing order of the layers.
//Defined in maputil.c
int msMoveLayerUp(mapObj *map, int nLayerIndex);
int msMoveLayerDown(mapObj *map, int nLayerIndex);
int msSetLayersdrawingOrder(mapObj *self, int *panIndexes);
char *msGetProjectionString(projectionObj *proj);
// Measured shape utility functions. =20
pointObj *getPointUsingMeasure(shapeObj *shape, double m);
pointObj *getMeasureUsingPoint(shapeObj *shape, pointObj *point);
char **msGetAllGroupNames(mapObj* map, int *numTok);
char *msTmpFile(const char *path, const char *ext);
imageObj *msImageCreate(int width, int height, outputFormatObj *format,=20
/* End of prototypes for functions in maputil.c =
/* prototypes for functions in mapswf.c =
imageObj *msImageCreateSWF(int width, int height, outputFormatObj =
*format,
char *imagepath, char *imageurl, mapObj =
*map);
void msImageStartLayerSWF(mapObj *map, layerObj *layer, imageObj =
*image);
int msDrawLabelSWF(imageObj *image, pointObj labelPnt, char *string,=20
labelObj *label, fontSetObj *fontset, double =
scalefactor);
int msDrawLabelCacheSWF(imageObj *image, mapObj *map);
void msDrawLineSymbolSWF(symbolSetObj *symbolset, imageObj *image, =
shapeObj *p,=20
void msDrawShadeSymbolSWF(symbolSetObj *symbolset, imageObj *image,=20
shapeObj *p, styleObj *style, double =
scalefactor);
void msDrawMarkerSymbolSWF(symbolSetObj *symbolset, imageObj *image,=20
pointObj *p, styleObj *style, double =
scalefactor);
int msDrawRasterLayerSWF(mapObj *map, layerObj *layer, imageObj *image);
int msDrawVectorLayerAsRasterSWF(mapObj *map, layerObj *layer, =
imageObj*image);
/*int msDrawWMSLayerSWF(int nLayerId, httpRequestObj *pasReqInfo,=20
int numRequests,=20
void msTransformShapeSWF(shapeObj *shape, rectObj extent, double =
cellsize);
int msSaveImageSWF(imageObj *image, char *filename);
void msFreeImageSWF(imageObj *image);
int draw_textSWF(imageObj *image, pointObj labelPnt, char *string,=20
scalefactor);
void msDrawStartShapeSWF(mapObj *map, layerObj *layer, imageObj *image,
shapeObj *shape);
#endif
/* End of prototypes for functions in mapswf.c =
/* prototypes for functions in mappdf.c =
#ifdef USE_PDF
imageObj *msImageCreatePDF(int width, int height, outputFormatObj =
*format,
*map);
void msImageStartLayerPDF(mapObj *map, layerObj *layer, imageObj =
*image);
int msDrawLabelPDF(imageObj *image, pointObj labelPnt, char *string,=20
scalefactor);
int msDrawLabelCachePDF(imageObj *image, mapObj *map);
void msDrawLineSymbolPDF(symbolSetObj *symbolset, imageObj *image, =
shapeObj *p,=20
void msDrawShadeSymbolPDF(symbolSetObj *symbolset, imageObj *image,=20
scalefactor);
void msDrawMarkerSymbolPDF(symbolSetObj *symbolset, imageObj *image,=20
scalefactor);
int msDrawRasterLayerPDF(mapObj *map, layerObj *layer, imageObj *image);
int msDrawVectorLayerAsRasterPDF(mapObj *map, layerObj *layer, =
imageObj*image);
void msTransformShapePDF(shapeObj *shape, rectObj extent, double =
cellsize);
int msSaveImagePDF(imageObj *image, char *filename);
void msFreeImagePDF(imageObj *image);
int msDrawTextPDF(imageObj *image, pointObj labelPnt, char *string,=20
scalefactor);
=20
void msDrawStartShapePDF(mapObj *map, layerObj *layer, imageObj *image,
shapeObj *shape);
#endif
/* End of prototypes for functions in mappdf.c =
/* prototypes for functions in mapoutput.c =
void msApplyDefaultOutputFormats( mapObj * );
void msFreeOutputFormat( outputFormatObj * );
outputFormatObj *msSelectOutputFormat( mapObj *map, const char =
*imagetype );
void msApplyOutputFormat( outputFormatObj **target, outputFormatObj =
*format,
int transparent, int interlaced, int =
imagequality );
const char *msGetOutputFormatOption( outputFormatObj *format,=20
const char *optionkey,=20
const char *defaultresult );
outputFormatObj *msCreateDefaultOutputFormat( mapObj *map,=20
const char *driver );
int msPostMapParseOutputFormatSetup( mapObj *map );
void msSetOutputFormatOption( outputFormatObj *format, const char *key,=20
const char *value );
void msGetOutputFormatMimeList( mapObj *map, char **mime_list, int =
max_mime );
outputFormatObj *msCloneOutputFormat( outputFormatObj *format );
int msOutputFormatValidate( outputFormatObj *format );
#ifndef gdImageTrueColor
# define gdImageTrueColor(x) (0)
#endif
/* prototypes for functions in mapgdal.c =
int msSaveImageGDAL( mapObj *map, imageObj *image, char *filename );
int msInitDefaultGDALOutputFormat( outputFormatObj *format );
/* End of prototypes for functions in mapoutput.c =
/* prototypes for functions in mapcopy =
int msCopyMap(mapObj *dst, mapObj *src);
int msCopyLayer(layerObj *dst, layerObj *src);
/* end prototypes for functions in mapcopy =
/* include definitions from mapows.h =
#include "mapows.h"
#endif
#ifdef __cplusplus
#endif
#endif /* MAP_H */
------=_NextPart_000_08F4_01C3F0B3.8D52EC60--
