[Mapserver-dev] Can someone test to see if the max number of layers can exceed 255?
Stephen Clark
stephen.clark at focus.ca
Thu Feb 12 20:05:00 EST 2004
This is a multi-part message in MIME format.
------=_NextPart_000_00EC_01C3F18A.5983B310
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
I think the problem is in the number of layers that can be allocated by =
its "Struct".
Any thoughts
Stephen
----- Original Message -----=20
To: mapserver-dev at lists.gis.umn.edu ; =
mapserver-users at lists.gis.umn.edu=20
Sent: Wednesday, February 11, 2004 3:27 PM
Subject: [Mapserver-users] Max number of layers craps out at about 295
Hi all,
I am trying to get the max number of layers that MS will read from a =
*.map file to be 500 or more.
Once I exceed about 295 layers the MAP file will not be displayed.
The error I get is 'The Memory could not be "read".' with some hex =
codes displayed.
I have attached my "map.h" file as reference.
Is there some other file that have to modify to be able to increase =
the number of layers?
thanks
Stephen
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML xmlns=3D"http://www.w3.org/TR/REC-html40" xmlns:o =3D=20
"urn:schemas-microsoft-com:office:office" xmlns:w =3D=20
"urn:schemas-microsoft-com:office:word"><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Diso-8859-1">
<META content=3DWord.Document name=3DProgId>
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR>
<META content=3D"Microsoft Word 10" name=3DOriginator><LINK=20
href=3D"cid:filelist.xml at 01C3F0D6.7488DD20" rel=3DFile-List><!--[if gte =
mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:HyphenationZone>21</w:HyphenationZone>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]-->
<STYLE>@page Section1 {size: 612.0pt 792.0pt; margin: 70.85pt 3.0cm =
70.85pt 3.0cm; mso-header-margin: 35.4pt; mso-footer-margin: 35.4pt; =
mso-paper-source: 0; }
P.MsoNormal {
FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman"; =
mso-style-parent: ""; mso-pagination: widow-orphan; =
mso-fareast-font-family: "Times New Roman"
LI.MsoNormal {
DIV.MsoNormal {
A:link {
COLOR: blue; TEXT-DECORATION: underline; text-underline: single
SPAN.MsoHyperlink {
A:visited {
COLOR: purple; TEXT-DECORATION: underline; text-underline: single
SPAN.MsoHyperlinkFollowed {
SPAN.EstiloDeEmail17 {
COLOR: windowtext; FONT-FAMILY: Arial; mso-style-type: =
personal-compose; mso-style-noshow: yes; mso-ansi-font-size: 10.0pt; =
mso-bidi-font-size: 10.0pt; mso-ascii-font-family: Arial; =
mso-hansi-font-family: Arial; mso-bidi-font-family: Arial
SPAN.SpellE {
mso-style-name: ""; mso-spl-e: yes
SPAN.GramE {
mso-style-name: ""; mso-gram-e: yes
DIV.Section1 {
page: Section1
</STYLE>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Tabela normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
</style>
<![endif]--></HEAD>
<BODY lang=3DPT-BR style=3D"tab-interval: 35.4pt" vLink=3Dpurple =
link=3Dblue=20
bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>I think the problem is in the number of =
layers that=20
can be allocated by its "Struct".</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>Any thoughts</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Stephen</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV style=3D"FONT: 10pt arial">----- Original Message ----- </DIV>
<DIV=20
style=3D"BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: =
black"><B>From:</B>=20
<A title=3Dstephen.clark at focus.ca =
href=3D"mailto:stephen.clark at focus.ca">Stephen=20
Clark</A> </DIV>
<DIV style=3D"FONT: 10pt arial"><B>To:</B> <A=20
title=3Dmapserver-dev at lists.gis.umn.edu=20
href=3D"mailto:mapserver-dev at lists.gis.umn.edu">mapserver-dev at lists.gis.u=
mn.edu</A>=20
; <A title=3Dmapserver-users at lists.gis.umn.edu=20
href=3D"mailto:mapserver-users at lists.gis.umn.edu">mapserver-users at lists.g=
is.umn.edu</A>=20
</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Sent:</B> Wednesday, February 11, =
2004 3:27=20
PM</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Subject:</B> [Mapserver-users] Max =
number of=20
layers craps out at about 295</DIV>
<DIV><BR></DIV>
<DIV><FONT face=3DArial size=3D2>Hi all,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I am trying to get the max number of =
layers that=20
MS will read from a *.map file to be 500 or more.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Once I exceed about 295 layers the =
MAP file will=20
not be displayed.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>The error I get is 'The Memory could =
not be=20
"read".' with some hex codes displayed.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I have attached my "map.h" file as=20
reference.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Is there some other file that have to =
modify to=20
be able to increase the number of layers?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>thanks</FONT></DIV>
<DIV><FONT face=3DArial =
size=3D2>Stephen</FONT></DIV></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_00EC_01C3F18A.5983B310--
