[Mapserver-dev] Proprietary Formats
Frank Warmerdam
warmerdam at pobox.com
Thu Jan 15 13:13:21 EST 2004
Ned Harding wrote:
> All,
> I am about to start adding support for a proprietary format or 2 into
> Mapserver that my company would need to start fully utilizing MapServer.
> It all looks pretty straight forward, but I wanted to do it in a generic way
> that might help other people, not hurt. I was thinking about adding a
> single new CONNECTIONTYPE that would look like PLUGIN(PluginName) that would
> route through a C++ pure virtual base class that could be registered at run
> time. The plugins would be added to a linked list (or a hash map) so that
> multiple could be instantiated at the same time.
> I would isolate the C++ code to a separate module so that it would not
> require a c++ compiler to build MapServer without this feature.
> This would make it much easier for 3rd party developers to add addition
> formats for specific instances of MapServer without having to touch the core
> code.
> Comments and advice would be appreciated.
Ned,
Would you consider implementing this plugin support at the OGR (or GDAL if
they are raster) levels? I already have a concept of run-time loadable
GDAL raster drivers, and have been intending to add it to the OGR side as
well. Or is this a situation where you really want to do alot of custom
rendering logic for the layers as well?
If it does make sense to do it at the MapServer layer level, I would suggest
that it be implemented as a C structure of function pointers for the various
layer entry points. This would be more in keeping with the C approach of
MapServer, and it wouldn't prevent you from implementing the custom layer
types in C++.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
