[Mapserver-dev] Problem with 4.2.0 Distribution
Paul Spencer
pspencer at dmsolutions.ca
Thu Jul 8 13:56:38 EDT 2004
David, I think this file and others that aren't easily generated are
available in the nightly builds from the umn download.
Cheers,
Paul
David W. Graham wrote:
> Maybe this is a bug, maybe not. But I was hoping to get a solution quickly.
> I am trying to compile the MapServer on Win32. The problem seems to be
> in the mapparser build system. If I understand it right mapparser.h is
> generated by the FLEX compiler using mapparser.y and mapparser.l. This
> is useful if you want to change/add tokens to the mapfile. But frankly
> I don't have this tool installed and I don't particularly want to. I
> have no need to edit the tokens. I have spent the entire morning
> working on getting together updated versions of all of the libraries so
> I could build mapscript. Could someone just send me a precompiled
> "mapparser.h" file?
> I am sorry if I sound frustrated, I have been working on C# MapScript
> and things are going well, but slow. In about a half of an hour I had
> downloaded SWIG, created all the mapscript objects and fixed them to
> compile in C#. All I needed to do to make things run was add
> mapscript_wrap.c to the contents of maplib.dll to make a new
> mapscript.dll. Well 4 hours later I still don't have a working
> compilation of mapserver.
> I think if I could get a mapparser.h file I would be on my way. Is it
> possible to get this put in the distribution for us Windows people?
> Dave Graham
|Paul Spencer pspencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
