Please help: "map context is not enabled"
Xiongjiu Liao
xliao at MIT.EDU
Sun Nov 28 12:15:07 EST 2004
Hello, everyone:
I am working on a project with Mapserver, but I meet some problems with
it,
would you please give some ideals? Really appreciate it.
a) here is the error message:
Warning: [MapServer Error]: msSaveMapContext(): Not implemented since Map
Context is not enabled. in /www/htdocs/context_script.php on line 4
Warning: Failed saving map context from gmap_wms_context_output.xml in
b) here is the php program I want to test:
<?php
dl("php_mapscript.so");
$oMap = ms_newMapObj("/www/htdocs/tutorial/context_test1.map");
$oMap->saveMapContext("gmap_wms_context_output.xml");
c) here is my Mapserver configure output:
./mapserv40 -v
MapServer version 4.2.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
d) here is my mapfile:
Map
NAME EX3.1_
status on
PROJECTION
"init=epsg:2163"
END
web
IMAGEPATH '/www/htdocs/tutorial/data/tmp/'
IMAGEURL '/tutorial/data/tmp/'
METADATA
"WMS_TITLE" "UMN MapServer Upper Great Lakes Application"
"WMS_ONLINERESOURCE"
"http://localhost/cgi-bin/mapserv40?map=context_test1.map&"
"WMS_SRS" "EPSG:2163 EPSG:4326 EPSG:26915 EPSG:26916"
END
end
LAYER
NAME states
DATA states_ugl
STATUS DEFAULT
TYPE POLYGON
METADATA
"wms_title" "Elevation/Bathymetry"
"wms_srs" "EPSG:42304 EPSG:4269 EPSG:4326"
END
#CONNECTIONTYPE WMS
#CONNECTION
"http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?#VERSION=1.1.0&LAYERS=bathymet
ry&FORMAT=image/png"
# PROJECTION
# "init=epsg:42304"
#END
END
end
Thank you very much!
