[Mapserver-dev] Optimizing for ArcSDE
Brock Anderson
banders at refractions.net
Tue Oct 19 15:36:47 EDT 2004
Hello Developers,
I am trying to speed up the ArcSDE code. Now that Mapserver can run in
fast-cgi mode we are able to pool SDE connections, which greatly reduces
response time for getMap requests. We're still not as fast as ArcIMS
(with the WMS connector) for similar getMap requests. Some timed
debugging statements indicate that there is still some slowdown in
msSDELayerOpen() and msSDELayerClose().
Howard Butler made some improvements to this code yesterday that helped
reduce the time cost for requesting default layer versions, but we are
still incurring about 20ms delay in opening and again in freeing
streams. For each layer. SE_stream_create() and SE_stream_free()
appear to communicate with the SDE server. Why else would there be any
time cost to these calls?
We could pool the streams to save this cost. Since we only ever use one
stream per connection, would it make sense to pool streams together with
connections? I was thinking we could create a new structure with both
the sde->connection, and the stream, and we could pass this to the
connection pooling API. The msSDECloseConnection() callback function
could be modified to close the stream, then the connection.
Does anyone have any suggestions? Would this approach work to save us
from the stream overhead? Do we even need a solution this complex, or
is there something simple that could alleviate this overhead?
Independent of streams, we are incurring about a 20ms cost in getting
layer info. Would it make sense to cache the layer infos? The layer
info probably shouldn't be cached with the connections.
I would appreciate your comments.
Brock Anderson
