4.6 release plan
Kralidis,Tom [Burlington] Tom.Kralidis at EC.GC.CA
Wed Apr 20 00:38:26 EDT 2005
Steve,
If you're keen on making GML3L0 into 4.6, I can help you test, etc.
..Tom
> -----Original Message-----
> From: UMN MapServer Developers List
> [mailto:MAPSERVER-DEV at LISTS.UMN.EDU] On Behalf Of Daniel Morissette
> Sent: Tuesday, 19 April, 2005 20:42
> To: MAPSERVER-DEV at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-DEV] 4.6 release plan
> Steve Lime wrote:
> > As long as you consider a partially implemented feature
> (like some of
> > the application specific schema stuff) as being legit to
> work on post
> > feature freeze, then I can live with this. I have two siginificant
> > pieces going on: the GML3/application schema stuff and GEOS
> > integration. The latter is almost finished, but the former
> is going to
> > take some time.  I'll port my changes for WFS GML to the WMS writer
> > and re-initiate some discussion on a couple of topics:
> >   - controlling WFS output type (GML2/GML3/????)
> >   - WFS schema creation
> >   - changes to WFS queries brought about by finer control of GML
> > output
> Well, the idea of the feature freeze is that after that date
> nothing should happen that would significantly break things
> so that we can reach our objective of fixing all critical
> bugs and having release quality by the planned release date.
> I have entered those two items in the Wiki page.
> The GEOS thing is the one that would scare me the most but
> you say that it's mostly done.
> With respect to the GML thing, it affects only WFS/WMS so
> it's not too bad if it's not finished yet, but would have to
> be completed in the next 2-3 weeks or otherwise this part may
> not have been properly tested for the release.
> BTW, I have found that the 6 weeks release cycle with 3 betas
> has worked really well in the past to produce a quality
> release in time, but if you or others think that this is too
> long then we could discuss other ideas.
> Daniel
>   Daniel Morissette               dmorissette at dmsolutions.ca
>   DM Solutions Group              http://www.dmsolutions.ca/
