MapServer Development Process?
Daniel Morissette dmorissette at DMSOLUTIONS.CA
Tue Jun 28 11:37:47 EDT 2005
Frank Warmerdam wrote:
> Ak!  So today I applied two patches fixing memory leaks. Are
> you suggesting even changes such as this would require a
> bugzilla entry?   I am just concerned about the amount of extra
> overhead this adds to a change that otherwise only takes a minute.
> I, for one, am less likely to make such little fixes if I end up needed
> a bug report for it.
I see your point and would not want the process to prevent people from
contributing, I can't even believe that I'm the one pushing for more
processes... but OTOH we've often seen half a dozen files being changed
and committed with a very cryptic CVS change comment and no clear
explanation of what the change was for, that's what I am the most
concerned about and where the requirement for bugs could help.
> I must confess that I didn't even put an entry in the HISTORY
> file since it seems to minor.
If you applied the fixes in the 4.6 branch as well then please include a
note in HISTORY.TXT since even the smallest fix matters in a point
release. If it's only in the main dev't trunk then it's probably not
necessary to list every minor change there.
Daniel
  Daniel Morissette               dmorissette at dmsolutions.ca
  DM Solutions Group              http://www.dmsolutions.ca/
