MS RFC 8: Pluggable External Feature Layer Providers
Daniel Morissette
dmorissette at DMSOLUTIONS.CA
Thu Oct 27 07:47:48 EDT 2005
Jani Averbach wrote:
> I would like to ask MS TSC to vote for this proposal. I am sorry that this
> came so late, but if this passes, it will be ready and implemented for coming 4.8
> before feature freeze.
You realize that Oct 31st is only 4 days away?
> The proposal is important because it actually implements the way to include external
> providers for Mapserver. As technically, it isn't very big because mostly all work
> has been done by MS-RFC-3 (vtable architecture).
> http://ms.gis.umn.edu/development/rfc/ms-rfc-8
In the proposal you wrote:
> Technical Solution
> * New MAP-file keyword PLUGINLIB with string argument. This keywords tells which library dynamically to load for this layer.
> * New connection type CUSTOM
So this means that the PLUGINLIB parameter needs to be set explicitly
for each layer that uses a given plugin? Is the value the full path to a
.so file (DLL on Windows)? e.g.
PLUGINLIB "/opt/mapserver/plugins/myplugin.so"
This could make it painful to migrate mapfiles from windows to Linux
because then you need to edit every single layer to change the path and
extension.
How about a more automated mechanism where we set a MS_PLUGIN_DIR
variable in the environment prior to calling MapServer or via a CONFIG
directive at the map level, then the PLUGINLIB becomes a PLUGIN keyword
whose value is the basename of the plugin file?
e.g. the example above becomes:
MAP
CONFIG "MS_PLUGIN_DIR" "/opt/mapserver/plugins"
LAYER
CONNECTIONTYPE CUSTOM
PLUGIN "myplugin"
END
END
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
