MS RFC 8: Pluggable External Feature Layer Providers
Sean Gillies
sgillies at FRII.COM
Thu Oct 27 08:50:58 EDT 2005
On Oct 27, 2005, at 5:47 AM, Daniel Morissette wrote:
> Jani Averbach wrote:
>> I would like to ask MS TSC to vote for this proposal. I am sorry
>> that this
>> came so late, but if this passes, it will be ready and implemented
>> for coming 4.8
>> before feature freeze.
> You realize that Oct 31st is only 4 days away?
>> The proposal is important because it actually implements the way
>> to include external
>> providers for Mapserver. As technically, it isn't very big
>> because mostly all work
>> has been done by MS-RFC-3 (vtable architecture).
>> http://ms.gis.umn.edu/development/rfc/ms-rfc-8
> In the proposal you wrote:
>> Technical Solution
>> * New MAP-file keyword PLUGINLIB with string argument. This
>> keywords tells which library dynamically to load for this layer.
>> * New connection type CUSTOM
> So this means that the PLUGINLIB parameter needs to be set explicitly
> for each layer that uses a given plugin? Is the value the full path
> to a
> .so file (DLL on Windows)? e.g.
> PLUGINLIB "/opt/mapserver/plugins/myplugin.so"
> This could make it painful to migrate mapfiles from windows to Linux
> because then you need to edit every single layer to change the path
> and
> extension.
> How about a more automated mechanism where we set a MS_PLUGIN_DIR
> variable in the environment prior to calling MapServer or via a CONFIG
> directive at the map level, then the PLUGINLIB becomes a PLUGIN
> keyword
> whose value is the basename of the plugin file?
> e.g. the example above becomes:
> MAP
> CONFIG "MS_PLUGIN_DIR" "/opt/mapserver/plugins"
> LAYER
> CONNECTIONTYPE CUSTOM
> PLUGIN "myplugin"
> END
> END
> Daniel
> Daniel Morissette dmorissette at dmsolutions.ca
> DM Solutions Group http://www.dmsolutions.ca/
Daniel,
I want to be able to use absolute paths instead of a combination of
relative path and environment variable or config property, and I
think others will also want this option.
Jani,
What would you think about a change from CONNECTIONTYPE CUSTOM ->
CONNECTIONTYPE PLUGIN? I think that the meaning of "PLUGIN" will be
more clear to users.
Sean
Sean Gillies
sgillies at frii.com
http://zcologia.com
