null values in GML
Steve Lime Steve.Lime at DNR.STATE.MN.US
Thu Dec 14 13:40:42 EST 2006
Probably need to fix the native driver anyway. The OGR connecter I
assume removes
the stars but what happens when the GML is output?
Steve
>>> "Bart van den Eijnden (OSGIS)" <bartvde at OSGIS.NL> 12/13/2006
6:48:02 AM >>>
Hi list,
just reporting back that the asterisk problem (*************) for null
values in the GML could be solved by using OGR to connect to the
shapefiles
instead of using the Mapserver native shapefile connector.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
