Fix for bug #1629
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Mon Feb 6 02:34:44 EST 2006
This is exactly what I had in mind.
I volunteer to work on this system on my (little) spare time.
Umberto
On 2/3/06, Paul Ramsey <pramsey at refractions.net> wrote:
> One of our April projects at Refractions is going to be a continuous
> build/test server for udig/geotools that will run cruisecontrol and
> full build/test sets all the time, against (and here is the tricky
> bit) all the data stores. So the server will also have instances of
> PostGIS, Oracle, SDE, DB2, MySQL and so on set up. With that basic
> infrastructure we should be able to run the Mapserver tests against a
> broad swath of data stores too, which should hopefully find some of
> the breakages which various folks find "obscure" because they don't
> have the particular server available when they test.
> On 3-Feb-06, at 3:50 AM, Umberto Nicoletti wrote:
> > I think we need to setup a server that will check out the sources
> > every night from cvs and will build them along with performing the
> > tests. The report would then be mailed to the mapserver-dev.
> > This central server then would have a standard environment that could
> > be replicated by the interested parties on their workstations if they
> > wanted to setup automated tests privately.
> > There could also be many different builds with different versions of
> > gdal, proj, with or without wms, etc. Should we make this an rfc,
> > maybe?
> > Regards,
> > Umberto
> > On 2/2/06, Sean Gillies <sgillies at frii.com> wrote:
> >>>> At the end of 2005, I committed a PostGIS DB makefile to mapserver/
> >>>> tests/makefile_postgis. The Python unit tests use this fixture.
> >>> Sean,
> >>> I just tried it and I see it depends on user postgres existing. I'm
> >>> not saying this is a bad assumption, but I will suggest it is
> >>> exactly
> >>> these sort of environment differences that make RDBMS based
> >>> autotesting difficult.
> >> Agreed. At least it's a start.
> >> Sean
