Perl vs PHP Mapscript
Tamas Szekeres szekerest at GMAIL.COM
Mon Jun 26 14:32:33 EDT 2006
Steve,
I would suggest to embed the description of the functions and structs into
the source code so we could extract the documentation automatically with an
appropriate tool, and keep that doc up to date as part of the automated
build process.
We could also identify easily if a function was exposed by SWIG
intentionally or accidentally.
Tamas
-----Original Message-----
From: UMN MapServer Developers List [mailto:MAPSERVER-DEV at LISTS.UMN.EDU] On
Behalf Of Stephen Woodbridge
Sent: Monday, June 26, 2006 7:04 PM
To: MAPSERVER-DEV at LISTS.UMN.EDU
Subject: Perl vs PHP Mapscript
Hi all,
I'm looking at the Mapscript documentation and some PHP methods for the
map object are not documented in the Mapscript API documentation.
Specifically:
array getLayersIndexByGroup(string groupname)
array getAllGroupNames()
array getAllLayerNames()
I haven't done a comparison, I just noticed these few. I hope this is a
documentation bug and not that PHP/Mapscript is diverging.
I also just checked swiginc/map.i and I do not see these in it.  :(
I think it is the responsibility of the PHP/Mapscript developers to
either update the swig bindings or to write a bug for all new mapscript
functionality that needs to be mirrored into swig mapscript AND vica
versa for swig mapscript developers to write a bug against PHP mapscript.
It is very frustrating to try and port code when the functionality does
not map across languages.
I might suggest adding specifically formatted comments that contains
strings that can be extracted automatically that would allow a perl
script to compare CLASS:(ATTRIBUTE|METHOD(ARGS)) between the two. This
could also be used to compare against the last run to generate a list of
new features that need to be documented.
Thoughts?
-SteveW
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.1.394 / Virus Database: 268.9.5/376 - Release Date: 2006.06.26.
No virus found in this outgoing message.
