msCopyShape partially implemented???
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Mon Jun 26 15:10:50 EDT 2006
I should be committing the C-API version of the GEOS support tonight and will
take care of this at that point. I think I'd opt for just setting the geometry to
NULL since it will be built automatically if needed...
Steve
>>> Tamas Szekeres <szekerest at GMAIL.COM> 6/24/2006 3:48:27 PM >>>
Developers,
The current CVS-HEAD contains the following implementation for msCopyShape:
int msCopyShape(shapeObj *from, shapeObj *to) {
int i;
if(!from || !to) return(-1);
for(i=0; i<from->numlines; i++)
msAddLine(to, &(from->line[i])); /* copy each line */
to->type = from->type;
to->bounds.minx = from->bounds.minx;
to->bounds.miny = from->bounds.miny;
to->bounds.maxx = from->bounds.maxx;
to->bounds.maxy = from->bounds.maxy;
if(from->text) to->text = strdup(from->text);
to->classindex = from->classindex;
to->index = from->index;
to->tileindex = from->tileindex;
if(from->values) {
to->values = (char **)malloc(sizeof(char *)*from->numvalues);
for(i=0; i<from->numvalues; i++)
to->values[i] = strdup(from->values[i]);
to->numvalues = from->numvalues;
/* TODO add GEOS copy, or at least initialize to->geometry to NULL */
return(0);
Without copying GEOS geometry will we run into unexpected problems?
Tamas
