Today's CVS, labels that follow street segments and antialias lines
Paul Spencer pspencer at DMSOLUTIONS.CA
Tue Mar 21 15:43:07 EST 2006
oh yes, you need PNG24.  Frank added a processing option(?) to allow
dithering of PNG24 to PNG8 which works quite nicely AFAIK (but I
haven't tried it yet, its on my todo list, I did it with PHP gd so I
assume it looks the same)
Cheers
Paul
On 21-Mar-06, at 3:23 PM, Stephen Woodbridge wrote:
> Also added TRANSPARENCY ALPHA to the LAYER, but still not AA.
> Do I need to define a special output format?
> Also MINDISTANCE does not seem to be working with ANGLE FOLLOW.
> I will recheck everything on this end and make sure everything is
> built corectly.
> -Steve W
>> Steve Lime wrote:
>>> There haven't been any recent changes that I know of that would
>>> cause problems along these lines.
>>> 1a) Benj's last patch was applied several weeks ago as mentioned
>>> in comment #31 of bug 1620.
>>> 1b) I'm running brand new CVS code here and MINDISTANCE is
>>> working as usual
>>> 2) Paul's right, the most naive style would be:
>>>        STYLE
>>>          COLOR 170 153 34
>>>          WIDTH 5
>>>          ANTIALIAS TRUE
>>>        END
>> OK, changing the mapfile to look like this, but reading the
>> threads on this I thought you could use SYMBOL "circle" with SIZE
>> n also.
>> How to I get dashed AA lines?
>> Thanks,
>>   -Steve W
>>> 3) I'll work up a test case for you. What should work is setting
>>> 2 styles: 1 for the fill and the second
>>> for the outline. E.g.:
>>> STYLE COLOR 255 0 0 END
>>> STYLE
>>>    COLOR 170 153 34
>>>    WIDTH 5
>>>    ANTIALIAS TRUE
>>> END
>>> Steve
>>>>>> Paul Spencer <pspencer at DMSOLUTIONS.CA> 3/21/2006 12:39:50 PM >>>
>>> Steve,
>>> re 1) the latest cvs had working labels following lines (more or
>>> less) when I last did it.  I didn't check mindistance though.
>>> And  there are still some outstanding issues I think (unless this
>>> is the  un-committed patch?)
>>> re 2) you need to change SYMBOL "circle" to SYMBOL 0, SIZE 3 to
>>> WIDTH  3 and set TRANSPARENCY ALPHA at the LAYER level.
>>> re 3) I'd like to know the same thing.  I never got polygons
>>> working :(
>>> Cheers
>>> Paul
>>> On 21-Mar-06, at 1:21 PM, Stephen Woodbridge wrote:
>>>> Hi all,
>>>> I grabbed today CVS and I'm testing it with ka-map. I have a
>>>> couple  questions/issues:
>>>> 1) labels that follow street segments
>>>>   a) Benj has a patch that need to get integrated when ever he
>>>> is  ready
>>>>      I didn't get it built into my test version yet.
>>>>   b) MINDISTANCE on labels is not working
>>>> 2) Fuzzy brushes / antialiasing does not seem to be working.
>>>> I'm  using png output and the mapfile fragment looks like:
>>>>    CLASS
>>>>      NAME "Interstate Highways"
>>>>      EXPRESSION "1"
>>>>      STYLE
>>>>        SYMBOL "circle"
>>>>        COLOR 170 153 34
>>>>        SIZE 5
>>>>        ANTIALIAS TRUE
>>>>      END
>>>>      STYLE
>>>>        SYMBOL "circle"
>>>>        COLOR 238 187 34
>>>>        SIZE 3
>>>>        ANTIALIAS TRUE
>>>>      END
>>>>    END
>>>> 3) How should I define a polygon layer so I can fill the
>>>> polygon  and outline it with antialiased?
>>>> Thanks,
>>>>  -Steve W
>>> |Paul Spencer                           pspencer at dmsolutions.ca   |
>>> |Applications & Software Development                              |
>>> |DM Solutions Group Inc                 http://
>>> www.dmsolutions.ca/|
> <tile.png>
|DM Solutions Group Inc                 http://www.dmsolutions.ca/|
