FW: [wfs-dev] summary of changes from wfs 1.0 to 1.1?
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Mon Oct 16 11:53:38 EDT 2006
FYI below. A good summary of changes for OGC:WFS 1.1 (thought I'm not
sure what MapServer plans are for supporting 1.1).
-----Original Message-----
From: wfs-dev-bounces+tom.kralidis=ec.gc.ca at opengeospatial.org
[mailto:wfs-dev-bounces+tom.kralidis=ec.gc.ca at opengeospatial.org] On
Behalf Of Panagiotis (Peter) A. Vretanos
Sent: 16 October, 2006 11:51 AM
To: Chris Holmes
Cc: geoserver-devel at lists.sourceforge.net; wfs-dev at opengeospatial.org;
Ian Turton
Subject: Re: [wfs-dev] summary of changes from wfs 1.0 to 1.1?
Chris,
Good summary.
However, F.Y.I, joins are being removed from the specification in the
next release.
Ciao.
Chris Holmes wrote:
> I just pulled this together from some notes that I made for our
> implementation, so it's a bit rough, but should give a decent starting
> point. We've got a basic WFS (caps, describe and getfeature) on a
> branch in GeoServer, and are close to done with transaction stuff.
> Justin may have some more to add, as he's been doing the
implementation.
> Soap Wrappers For all operations
> Get Feature WFS 1.1
> Results as hits
> SortBy
> Reprojection
> * Xlink properties (get gml object stuff)
> GML 3.1.1
> Describe WFS 1.1
> GML 3.1.1 (no other changes afaik)
> Transaction WFS 1.1
> Reprojection in Insert
> IdGen options:
> GenerateNew (default)
> The web feature service shall generate unique identifiers for all
> newly inserted feature instances.
> UseExisting
> In response to an <Insert> operation, a web feature service shall
> use the gml:id attribute values on inserted features and elements. If
> any of those IDs duplicates the ID of a feature or element already
> stored in the WFS, the WFS shall raise an exception.
> ReplaceDuplicate
> A WFS client can request that the WFS generate IDs to replace the
> input values of gml:id attributes of feature elements that duplicate
> the ID of a feature or element already stored in the WFS, instead of
> raising an exception, by setting the idgen attribute of the
> InsertElementType to the value "ReplaceDuplicate".
> LockFeature WFS 1.1 No changes, except GML 3.1.1
> GetGMLObject WFS 1.1
> New Operation (that doesn't make much sense imho, we're not
> implementing for WFS 1.1) tells the server to return remote xlinks.
> GetCapabilities WFS 1.1
> SRS reporting
> GetGMLObject caps mods
> Version negotiation (not new, but wasn't an issue before with just
> one version of spec)
> Filter 1.1
> GML 3.1.1 parser
> SortBy
> Joins
> Chris
> Ian Turton wrote:
>> Does any one have a document that summarises the changes between the
>> WFS 1.0 and 1.1 specifications? If not I guess I'll have to read
>> through the specs and the change requests and work it out but
>> obviously if someone else has already done this that would be great.
>> Thanks
>> Ian
> wfs-dev mailing list
> https://mail.opengeospatial.org/mailman/listinfo/wfs-dev
Panagiotis (Peter) A. Vretanos CubeWerx Inc.
Big Kahuna (Senior Database Developer) http://www.cubewerx.com
Tel. 416-701-1985 Fax. 416-701-9870 pvretano at cubewerx.com
"If you want to make an apple pie from scratch, you must first
create the universe." -- Carl Sagan
