SDE 9.2 - Libs
Hr. Johannes Loose loose at LWF.UNI-MUENCHEN.DE
Thu Aug 2 09:15:37 EDT 2007
Hello List
I am trying to compile mapserver 4.10.2  with ArcSDE 9.2 support.
Compiling has worked fine for SDE 9.1 using the sdeexe91 tree (including sdetype.h /
libsde91.a / libsde91.so). The sdeexe92 tree does NOT contain the files sdetype.h,
libsde92.a, libsde92.so. Hence the configure script is not able to find that files and prints out
the related error. The flags i used for the configure script are: --with-sde-version=92 --with-
sderaster --with-sde=[PATH]/sdeexe92/lib
How can this be fixed?
Thanks in advance for any helping reply :-)
Johannes Loose
