Status of RFC 31
Steve Lime Steve.Lime at DNR.STATE.MN.US
Wed Aug 8 17:30:23 EDT 2007
> What do you mean by how to deal?
I mean to we want to expose that function name "as is", so you'd do:
  $map = mapscript::msLoadMapFromString($string);
or would it be better to handle it some other way.
Steve
>>> Sean Gillies <sgillies at FRII.COM> 08/08/07 3:21 PM >>>
Steve Lime wrote:
> It's basically done (except for the URLPATTERN , rats) but needs testing and some documentation of course. I added "updateFromString()" methods
> to all mapscript objects. The string loader for a mapfile only exists as a direct call to msLoadMapFromString, I didn't change the constructor for a mapObj,
> not sure how that would work.
   >>> map = mapscript.fromstring("""MAP ... END""")
that seems pretty simple. It would be good enough for 5.0 if this always
returned a mapObj or raised an exception. Later, you could add logic to
let it create layers or others.
> Stuff "todo":
>   - figure out how to deal with msLoadMapFromString
>   - update PHP/MapScript with the updateFromString methods (will create a bug)
>   - create a documentation bug
>   - develop some test cases
> Any help appreciated...
> Steve
I already committed one test, and will add more.
Cheers,
Sean
