Debug 2
John Cole
john.cole at UAI.COM
Fri Aug 24 09:13:31 EDT 2007
Done. I hope I explained it well enough :-)
Thanks,
John
Daniel Morissette-2 wrote:
> John Cole wrote:
>> The odd thing is that it doesn't corrupt the image when mode=browse,
>> the
>> stderr is only redirected with the html template, not the images going to
>> the tmp dir. Seems like there is some code in there to figure out when
>> it
>> can append stderr and when it shouldn't somewhere, otherwise I'd expect
>> to
>> see the debugging info appear in the legend, scalebar and map as well.
> That's normal since the problem is only that stderr is redirected to
> stdout by IIS. In mode=browse, stdout is used only to output the HTML
> template. The map, legend and scalebar images are written to temporary
> files on disk directly (not to stdout), that's why the stderr doesn't
> corrupt them.
>> In 4x, debug=on would corrupt WFS queries, but not map requests (or
>> scalebar, legend or legendgraphic requests).
> In the WFS case, the XML response is written to stdout, that's why it
> gets corrupted.
> mode=map or mode=legend would have been corrupt in 4.x as well since
> they send their output to stdout which would be corrupted by stderr
> debug messages under IIS.
> There too, the easy solution
>> is to turn debugging off (or now go to a file). It's just an
>> inconvenience
>> that should probably be documented in in the reference near the MAP.DEBUG
>> section, just to avoid some of the image corruption questions.
> Can you please add a comment to that effect to the bottom of the page in
> the website and they'll catch it when they do the docs update.
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
View this message in context: http://www.nabble.com/Debug-2-tf4320239.html#a12312182
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
