AGG Build problem
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Fri Aug 24 13:15:56 EDT 2007
OK, thanks for the heads up.
I wonder why that is?
Thanks,
-Steve
Huey Brantley wrote:
> I built on CENTOS fine except I couldn't use AGG 2.4 I downloaded.
> Couldn't get it to locate the libs properly. I later did yum install
> agg-devel and MS5 builds fine.
> -h
> On Fri, 2007-08-24 at 11:05 -0400, Stephen Woodbridge wrote:
>> Hi,
>> I was trying to build mapserver on Centos 5? box and ran into a strange
>> error trying to build with AGG support.
>> I don't have the exact error message here, but it was something about
>> mapagg.cpp:224 complaining about gdImageGetTrueColorPixel not being
>> available in some C++ context.
>> Without AGG, it built fine. The system has GD-2.0.23 installed. If AGG
>> has a requirement for a newer version of GD we should test and catch
>> this in configure.
>> Any thoughts on this. Has anyone else run into this?
>> Everything builds fine on my Debian box with GD-2.0.33 installed.
>> -Steve W
