AGG Build problem
thomas bonfort
thomas.bonfort at GMAIL.COM
Fri Aug 24 13:34:17 EDT 2007
no idea here...
there was a bug report acouple of weeks ago on a strange compilation error
on centos due to the fact that the shipped agg package had a bug (agg
versions are actually different even if they have the same version number,
i.e., there are no 2.4.1, etc, versions). In that case the compile error
disappeared when using the latest 2.4 package from antigrain.
I've checked the gd source, and gdImageGetTrueColorPixel in 2.0.23 is the
same than in 2.0.35 (although in 2.0.35 it is declared as extern int instaed
of only int).
so perhaps you could try with a recent source distribution of agg and see
what gives
tb
On 8/24/07, Stephen Woodbridge <woodbri at swoodbridge.com> wrote:
> OK, thanks for the heads up.
> I wonder why that is?
> Thanks,
> -Steve
> Huey Brantley wrote:
> > I built on CENTOS fine except I couldn't use AGG 2.4 I downloaded.
> > Couldn't get it to locate the libs properly. I later did yum install
> > agg-devel and MS5 builds fine.
> > -h
> > On Fri, 2007-08-24 at 11:05 -0400, Stephen Woodbridge wrote:
> >> Hi,
> >> I was trying to build mapserver on Centos 5? box and ran into a strange
> >> error trying to build with AGG support.
> >> I don't have the exact error message here, but it was something about
> >> mapagg.cpp:224 complaining about gdImageGetTrueColorPixel not being
> >> available in some C++ context.
> >> Without AGG, it built fine. The system has GD-2.0.23 installed. If AGG
> >> has a requirement for a newer version of GD we should test and catch
> >> this in configure.
> >> Any thoughts on this. Has anyone else run into this?
> >> Everything builds fine on my Debian box with GD-2.0.33 installed.
> >> -Steve W
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20070824/29fbc796/attachment.html
