MapServer 4.10.3 released with security fix
Daniel Morissette dmorissette at MAPGEARS.COM
Fri Aug 24 14:47:13 EDT 2007
Yes, that's probably a 4.10.3 bug. I had fixed a similar issue with PHP
MapScript while testing just before the 4.10.3 release. Can you please
file a ticket so that the SVN in branch-4-10 is fixed. We may not
release another 4.10.x, but at least if we do the fix will be in SVN
already.
Daniel
Nicol Hermann wrote:
> Dear developer,
> Am Mittwoch, den 22.08.2007, 17:44 -0400 schrieb Daniel Morissette:
>> MapServer 4.10.3 has just been released with some security fixes.
> <cut>
>> Daniel
>> Version 4.10.3 (2007-08-22)
> <cut>
>> - Rename libmap.a to libmapserver.a for commonality with
>>    libmapserver.so (#2150)
> is it possible that java mapscript do not respect this change.
> When i try to compile the java mapscript of version 4.10.3 with
> cd mapscript/java
> make interface
> make
> i get the error message
> /usr/bin/ld: cannot find -lmap
> collect2: ld returned 1 exit status
> make: *** [mapscript_so] Error 1
> When i rename lmap to lmapserver in the Makefile everything is fine.
> i think this is a bug
> Nicol
Daniel Morissette
http://www.mapgears.com/
