msautotest on Windows (buildbot) for MapServer 5.0
Normand Savard nsavard at MAPGEARS.COM
Tue Aug 28 08:20:04 EDT 2007
I checked the reason why the msautotest failed on buildbot for MapServer
5.0 (szekerest-vc80-ful).  Most of the tests that return text file (xml,
gml, html) failed because they have a "crlf" on each line and the
expected results contain only "lf".  I modified the msautotest python
script to process the "crlf" to "lf".
I noticed that the wxs/sld tests failed because the projection 42304 is
not found (see the error message below).  The projection is defined in
the map file as:
PROJECTION
 "init=./data/epsg2:42304"
END
The epsg2 file is really in the data directory.  I have no idea right
now why it doesn't find the projection file on this Windows machine.
The Windows machine at our office didn't meet this issue.
Finally some of the tests failed because of floating point rounding
rules difference between Windows and Unix.  These tests need to be
validated visually and move to the expected directory.  They are:
in gdal:
in misc:
Norm
Response of the map server:
<ServiceException>
msProcessProjection(): Projection library error. no options found in
&#39;init&#39; file
</ServiceException>
