Status of AGG support?
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Tue Jul 3 22:38:15 EDT 2007
Paul, Steve, et al,
I have mapserver trunk built with AGG but have little clue on how to use
it at this point. Googling shows up two trac tickets #2114 and #2115
which show:
OUTPUTFORMAT
NAME "agg/png24"
MIMETYPE "image/png; mode=24bit"
DRIVER "AGG/PNG"
EXTENSION "png"
IMAGEMODE "RGB"
FORMATOPTION "PALETTE_FORCE=TRUE"
FORMATOPTION "PALETTE=/my/path/palette.txt"
END
So this looks like the deal. What is palette.txt and does one define
that. I assume this controls the problem with tiles shifting colors
because the color palette overflows based on the anti-aliasing using up
the color slots. Is this then a list of the primary colors that you want
pre-allocated in you image so they do not shift.
What is the format of the file?
Thanks,
-Steve
Paul Spencer wrote:
> The other thing that I am very keen to have is text rendered/placed
> using AGG. Not sure if it will be done for 5.0 though.
> Cheers
> Paul
> On 3-Jul-07, at 1:25 PM, Steve Lime wrote:
>> Hi Tom: AGG support is in the codebase for 5.0. I still owe an RFC to
>> explain what was
>> done although the addition of AGG doesn't affect any other portions of
>> MapServer. It's
>> a big user feature though. I recently got a big time sink off my plate
>> and will work that up
>> ASAP.
>> The support is relatively complete. The guys from DM Solutions can
>> probably comment
>> further as they've been using it the most. The AGG vs. GD images DM
>> has supplied are
>> very nice. The quality difference is noticeable with roads in particular.
>> The only missing capability that I am aware of has to do with PIXMAP
>> symbols that contain
>> an alpha channel. There is a fundamental difference in how AGG and GD
>> handle alpha
>> blending (GD is flat out backwards). We use GD to manage the pixel
>> buffer that AGG is
>> rendering into so that becomes a problem. I'll go into options in the
>> RFC.
>> Anyway, other than that the support seems to be working nicely is
>> worth trying.
>> Steve
>>>>> On 7/1/2007 at 10:08 PM, in message
>> <7b5b710d0707012008i59c41e8bq8e0ef4d8022f40f8 at mail.gmail.com>, Tom Beard
>> <tom at PROJECTX.CO.NZ> wrote:
>>> Hi there,
>>> This is my first time posting here, and I hope this is the right
>>> forum to
>>> ask this question.
>>> I was wondering what the status of AGG support was for the 5.0
>>> release. On
>>> searching the archives, the most recent reference I could find was the
>>> minutes from the May 22 IRC meeting that said that there would be an RFC
>>> freeze on June 15, and that an RFC for AGG was "forthcoming". Did AGG
>>> support make it into that freeze? Is it listed somewhere online?
>>> I'd also be interested to know if there is a version currently in
>>> Subversion
>>> that includes AGG sub-pixel rendering and that works well enough to
>>> have a
>>> go at compiling on Windows.
>>> Regards,
>>> Tom Beard
> |Paul Spencer pspencer at dmsolutions.ca |
> |Chief Technology Officer |
> |DM Solutions Group Inc http://www.dmsolutions.ca/ |
