INCLUDE and php-mapscript ?
Daniel Morissette
dmorissette at MAPGEARS.COM
Thu Jul 5 13:18:54 EDT 2007
Do you use a relative path or an absolute path for your include
statement in the main mapfile? Just trying to rule out the possibility
of a problem related to the way relative paths are handled by PHP
MapScript vs the include directive.
Daniel
Attila Csipa wrote:
> Has anyone tried to use a .map file with INCLUDE statements from
> php-mapscript ? I'm getting the following error:
> Warning: [MapServer Error]: loadLayer(): in /var/www/ka-map/htdocs/init.php on
> line 113
> Warning: Failed to open map file /var/www/mapdata/data3/6.map
> in /var/www/map/htdocs/init.php on line 113
> the "INCLUDE /var/www/mapdata/common/circles.map" is a list of CLASS
> statements which are inside a LAYER
> CLASS
> NAME "Your Circle"
> EXPRESSION ([itemid] = 6)
> SYMBOL 'circle'
> MINSCALE 75000
> MAXSIZE 20
> MINSIZE 10
> COLOR 0 0 0
> END
> the odd thing is that it does work if I just copy/paste the contents of the
> include file, and it works correctly WITH the include if called from shp2img.
> All of this with Mapserver 4.10.2.
Daniel Morissette
http://www.mapgears.com/
