error with msencrypt
Daniel Morissette
dmorissette at MAPGEARS.COM
Tue Jun 5 07:36:05 EDT 2007
Nicol Hermann wrote:
> msencrypt: mapcrypto.c:331: msEncryptStringWithKey: Assertion
> `sizeof(unsigned long) == 4' failed.
> Do you have any idea what is going wrong?
> I tried the latest stable version 4.10.2 .
Are you on a 64 bits system? If yes then there is a fix for this in the
dev version, see http://trac.osgeo.org/mapserver/ticket/1928
I was not planning to backport this to 4.10 to avoid causing any
unexpected side-effect, but if really necessary the fix could be backported.
Daniel
Daniel Morissette
http://www.mapgears.com/
