Documenting the breaking changes
Tamas Szekeres
szekerest at GMAIL.COM
Tue Jun 5 15:45:07 EDT 2007
I can accept the suggestion to have a primary location but someone
should create the skeleton document ready to fill. In my understanding
if we would like to publish the document via the mapserver site we
should continue to use the reStructured text format. If we would
rather use the mapserver trac for this purpose we should probably use
a wiki page instead. Anyway I would keep the older versions somewhere
available for a later review of the folks.
I'm also curious about the practical side of this question that is:
How can we ensure that all of the backward incompatible changes will
be documented? Shouldn't we set up a policy to document the change
right after committing into the SVN trunk? Such as we use the
HISTORY.TXT at the moment.
Best regards,
Tamas
2007/6/5, Daniel Morissette <dmorissette at mapgears.com>:
> Tamas Szekeres wrote:
> > Folks,
> > I think it takes a fair amount of work to document the backward
> > incompatible changes between the 4.10 and the upcoming 5.0 release so
> > it worth starting this effort in time. Recall that we have a
> > MIGRATION_GUIDE.TXT in the project tree to enumerate these changes in
> > a convenient way.
> Oopps... I had forgotten that we had a MIGRATION_GUIDE.TXT in the source
> tree. I had already started a 4.10 -> 5.0 migration guide in the website at:
> http://mapserver.gis.umn.edu/development/release_plans/migration_guide_410_50/
> > May I suppose that we would want to continue this documentation or we
> > should open up a brand new one?
> Perhaps the best would be to flush the current contents of
> MIGRATION_GUIDE.TXT and start fresh (in the same file) with the 4.10 ->
> 5.0 migration guide.
> We could also perhaps keep the 4.8->4.10 stuff at the end of the file,
> but then the file would become quite large and that could confuse users.
> Either way, I think we need to make an effort to keep the
> MIGRATION_GUIDE.TXT from the source tree and the website page at the URL
> above in sync. The MIGRATION_GUIDE.TXT in SVN should be considered the
> master and the website version just a copy, so any change needs to be
> made to the master in SVN first. A note to that effect could be added in
> the website copy.
> My 0.02$
> Daniel
> Daniel Morissette
> http://www.mapgears.com/
