MSVCR80.DLL
Hallgren Johan E jhhal at WMDATA.COM
Wed Mar 21 16:33:12 EDT 2007
Hello Tamas
The main problem was probably the Microsoft.VC80.CRT.manifest-file.
After added that file my problems was gone (so far).
Thanks for your assistance.
/Johan
___________________________________
Johan Hallgren
WM-data a LogicaCMG company
Pelle Bergs backe 3
Box 1938, 791 19 Falun
Tel: 023-547 46 (int: +46-2354746)
Mobil: 070-588 44 28 (int: +46-705884428)
johan.e.hallgren at wmdata.com
http://www.wmdata.se
-----Original Message-----
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: den 19 mars 2007 22:04
To: Hallgren Johan E
Cc: MAPSERVER-DEV at lists.umn.edu
Subject: Re: MSVCR80.DLL
Johan,
If you have no VS 2005 installed on your target computer you should
try to compile mapserver/mapscript without the /debug options. You
might also have to replace /Zi with /Ox in nmake.opt.
Alternatively you might install the Microsoft Visual C++ 2005
Redistributable Package
http://www.microsoft.com/downloads/details.aspx?FamilyId=32BC1BEE-A3F9-4
C13-9C99-220B62A191EE&displaylang=en
Best regards,
Tamas
PS: There's no need to manually embed the manifests into the
executables of the VS2005 builds any more. I've updated the necessary
changes to the CVS-HEAD and Branch-4-10 so this operation should be
executed automatically during the builds.
2007/3/19, Hallgren Johan E <jhhal at wmdata.com>:
> I have compile MapServer on windows version 4.10
> What ever I'm doing I have problems when moving the code to an other
> computer. While using Dependency Walker on libmap.dll it reports that
> MSVCR80.dll and MSVCP80.dll are missing. I thougth those should be
installed
> with DotNet 2.0. Must the dll-s be included at the runtime dir?
> I tries the shp2img.exe but it also fails.
> /Johan
> Johan Hallgren
> WM-data
> Pelle Bergs backe 3
> Tel (och mobil): 023-547 46 (int:
+46-2354746)johan.e.hallgren at wmdata.com
