MSVCR80.DLL
Tamas Szekeres
szekerest at GMAIL.COM
Wed Mar 21 17:29:22 EDT 2007
Johan,
I've recently updated the common and the csharp makefile.vc to embed
the manifests as a resource into the executables for the VC2005
builds. So I suggest to use the CVS version.
Best regards,
Tamas
2007/3/21, Hallgren Johan E <jhhal at wmdata.com>:
> Hello Tamas
> The main problem was probably the Microsoft.VC80.CRT.manifest-file.
> After added that file my problems was gone (so far).
> Thanks for your assistance.
> /Johan
> ___________________________________
> Johan Hallgren
> WM-data a LogicaCMG company
> Pelle Bergs backe 3
> Box 1938, 791 19 Falun
> Tel: 023-547 46 (int: +46-2354746)
> Mobil: 070-588 44 28 (int: +46-705884428)
> johan.e.hallgren at wmdata.com
> http://www.wmdata.se
> -----Original Message-----
> From: Tamas Szekeres [mailto:szekerest at gmail.com]
> Sent: den 19 mars 2007 22:04
> To: Hallgren Johan E
> Cc: MAPSERVER-DEV at lists.umn.edu
> Subject: Re: MSVCR80.DLL
> Johan,
> If you have no VS 2005 installed on your target computer you should
> try to compile mapserver/mapscript without the /debug options. You
> might also have to replace /Zi with /Ox in nmake.opt.
> Alternatively you might install the Microsoft Visual C++ 2005
> Redistributable Package
> http://www.microsoft.com/downloads/details.aspx?FamilyId=32BC1BEE-A3F9-4
> C13-9C99-220B62A191EE&displaylang=en
> Best regards,
> Tamas
> PS: There's no need to manually embed the manifests into the
> executables of the VS2005 builds any more. I've updated the necessary
> changes to the CVS-HEAD and Branch-4-10 so this operation should be
> executed automatically during the builds.
> 2007/3/19, Hallgren Johan E <jhhal at wmdata.com>:
> > I have compile MapServer on windows version 4.10
> > What ever I'm doing I have problems when moving the code to an other
> > computer. While using Dependency Walker on libmap.dll it reports that
> > MSVCR80.dll and MSVCP80.dll are missing. I thougth those should be
> installed
> > with DotNet 2.0. Must the dll-s be included at the runtime dir?
> > I tries the shp2img.exe but it also fails.
> > /Johan
> > Johan Hallgren
> > WM-data
> > Pelle Bergs backe 3
> > Tel (och mobil): 023-547 46 (int:
> +46-2354746)johan.e.hallgren at wmdata.com
