linking Trac and subversion
    Tamas Szekeres
    szekerest at GMAIL.COM
    Wed May  2 12:12:48 EDT 2007
I would suggest an update in
http://mapserver.gis.umn.edu/development/rfc/ms-rfc-7/
Best regards,
Tamas
2007/5/2, Kralidis,Tom [Burlington] <Tom.Kralidis at ec.gc.ca>:
> > -----Original Message-----
> > From: UMN MapServer Developers List
> > [mailto:MAPSERVER-DEV at LISTS.UMN.EDU] On Behalf Of Bart van
> > den Eijnden (OSGIS)
> > Sent: 02 May, 2007 11:49 AM
> > To: MAPSERVER-DEV at LISTS.UMN.EDU
> > Subject: [UMN_MAPSERVER-DEV] linking Trac and subversion
> > Hi list,
> > why are the developers not using links between Trac and svn?
> > In the Trac ticket you can do something like:
> > Fixed in changeset:6072, which will create a link to the
> > changeset in which the ticket was fixed.
> > Also, when doing an svn commit one should use the ticket:
> > syntax in the message, for instance:
> > svn commit -m "ticket:2079 WMS request with a BBOX and and
> > SLD containing Filter encoding gives inconsistent result"
> Good to know!!  If this is the agreed-upon approach, this would be
> useful.
> ..Tom
