linking Trac and subversion
Sean Gillies
sgillies at FRII.COM
Wed May 2 12:14:33 EDT 2007
Bart van den Eijnden (OSGIS) wrote:
> Hi list,
> why are the developers not using links between Trac and svn?
> In the Trac ticket you can do something like:
> Fixed in changeset:6072, which will create a link to the changeset in which
> the ticket was fixed.
> Also, when doing an svn commit one should use the ticket: syntax in the
> message, for instance:
> svn commit -m "ticket:2079 WMS request with a BBOX and and SLD containing
> Filter encoding gives inconsistent result"
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
It's just that Trac is new, Bart, but some of us are doing it. See for
example:
http://trac.osgeo.org/mapserver/changeset/6064?new_path=trunk%2Fmapserver
If you're watching the commits feed, you should see a link straight to
ticket 2083.
Sean
