Motion: Include MS SQL Server 2008 Native Driver in 5.2
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Mon Nov 12 22:01:24 EST 2007
Howard,
+1 on the proposal
Thank you for your patience with all my questions.
As an aside, to this, plugin is not a documented CONNECTIONTYPE in the
mapfile reference and a search on the mapserver website does not show
much that is useful regarding "plugin". I seems to me that there should
be a doc page the lists all available PLUGIN modules and has supporter
contact information (if not the mapserver dev) and where they can be
located and where to find external docs if they exist.
Thanks,
   -Steve W
Howard Butler wrote:
>>> On Nov 12, 2007, at 5:30 PM, Stephen Woodbridge wrote:
>>>> Does this need an RFC?
>>> I don't think so.  It is only new functionality, does not affect core
>>> functionality, and has no backward compatibility issues.
>>>> are there any mapfile changes, documentation changes, autotest
>>>> files, howtos (already mentioned the vector howto, how about the
>>>> build howtos, others?), are there mapscript implications.
>>> No to all of these.  Build configuration info will continue to be in
>>> nmake.opt as it is for all other drivers.  We don't maintain database
>>> instances for any of the other drivers for the autotest suite.
>>> MapScript will continue to see it like it does any other driver.
>>> Howard
>> OK, now I'm very confused! How does someone access this data source if
>> nothing changes? There at least needs to be a new CONNECTION and/or
>> CONNECTIONTYPE doesn't there?
> No.  The driver will only be accessible via the CONNECTIONTYPE PLUGIN
> http://mapserver.gis.umn.edu/development/rfc/ms-rfc-3/ One great
> advantage of the plugin architecture is that it eliminates the need for
> us to embed new connection types in MapServer and conditionally compile
> lots of different things in depending on which switches are turned on.
>> There probably needs to be a bug to track the change and address
>> questions like these.
> There will be a bug # and HISTORY.TXT changes to track these
> developments...
> Howard
