[mapserver-dev] Support for the AGG renderer in drawLegendIcon.
Tamas Szekeres
szekerest at gmail.com
Thu Aug 14 10:29:47 EDT 2008
It's already implemented in the trunk I've just missed it, because
I've been testig with the 5-0 branch.
Best regards,
Tamas
2008/8/14 Daniel Morissette <dmorissette at mapgears.com>:
> My preference would also be to make whatever change is required to move that
> down inside msDrawLegendIcon(). I wonder why that was not dont in the first
> place, perhaps Thomas, or whoever wrote msDrawLegendIconAGG() can comment on
> that before we make the final decision?
> Daniel
> Tamas Szekeres wrote:
>> Hi All,
>> I'd like to add AGG renderer support when creating the legend icons
>> from the mapscript interface. The corresponding function in class.i
>> would look something like:
>> int drawLegendIcon(mapObj *map, layerObj *layer, int width, int
>> height, imageObj *dstImage, int dstX, int dstY) {
>> if(map->outputformat->renderer == MS_RENDER_WITH_AGG)
>> return msDrawLegendIconAGG(map, layer, self, width, height,
>> dstImage, dstX, dstY);
>> else
>> return msDrawLegendIcon(map, layer, self, width, height,
>> dstImage->img.gd, dstX, dstY);
>> Any objections to apply such change?
>> I'd personally prefer including this stuff in the msDrawLegendIcon
>> itself, however if would require to change other portions of the code
>> like msDrawLegend in the mapserver core, and function above should
>> pass dstImage instead of dstImage->img.gd.
>> Best regards,
>> Tamas
>> mapserver-dev mailing list
>> mapserver-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
> Daniel Morissette
> http://www.mapgears.com/
