[mapserver-dev] Mapserver 5.0.X breaks GetFeatureInfo in ArcGIS
9.2
Frank Warmerdam
warmerdam at pobox.com
Sun Feb 17 11:14:05 EST 2008
Bart van den Eijnden (OSGIS) wrote:
> Hi list,
> we' ve got another case of where being a strict OGC WMS breaks
> interoperability because of a WMS client "misbehaving".
> To give you some background:
> -in ArcGIS 9.1 GetFeatureInfo did not work since ArcGIS did not send the
> required LAYERS parameter
> -in ArcGIS 9.2 GetFeatureInfo worked as text/plain
> Now it turns out that 9.2 does not work against Mapserver 5.0.X, since
> it omits the FORMAT parameter in the request and Mapserver checks on
> this. I must admit that I find it strange that this parameter is
> required for GetFeatureInfo as it makes no sense at all for those requests.
> Questions:
> -does this need RFC-35 to get revived or can we agree on just leaving
> out the check for FORMAT in the GetFeatureInfo request (and maybe hint
> OGC at removing that as well)?
Bart,
I'm ok with relaxing the checking. If those interested in strict
compliance with the specification are not satisfied with this approach
then I think we would need to revisit RFC 35.
> -does this warrant a 5.0.3 release?
I would think we role this into 5.0 branch and we issue a 5.0.3 release
when we have enough fixes to justify it. You can certainly deploy the changes
in your servers sooner than 5.0.3 is issued.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
