[mapserver-dev] Mapserver 5.0.X breaks GetFeatureInfo in ArcGIS9.2
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Mon Feb 18 07:09:38 EST 2008
> -----Original Message-----
> From: mapserver-dev-bounces at lists.osgeo.org
> [mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of
> Frank Warmerdam
> Sent: 17 February, 2008 11:14 AM
> To: Bart van den Eijnden (OSGIS)
> Cc: mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] Mapserver 5.0.X breaks
> Bart van den Eijnden (OSGIS) wrote:
> > Hi list,
> > we' ve got another case of where being a strict OGC WMS breaks
> > interoperability because of a WMS client "misbehaving".
> > To give you some background:
> > -in ArcGIS 9.1 GetFeatureInfo did not work since ArcGIS did
> not send
> > the required LAYERS parameter -in ArcGIS 9.2 GetFeatureInfo
> worked as
> > text/plain
> > Now it turns out that 9.2 does not work against Mapserver
> 5.0.X, since
> > it omits the FORMAT parameter in the request and Mapserver
> checks on
> > this. I must admit that I find it strange that this parameter is
> > required for GetFeatureInfo as it makes no sense at all for
> those requests.
> > Questions:
> > -does this need RFC-35 to get revived or can we agree on
> just leaving
> > out the check for FORMAT in the GetFeatureInfo request (and
> maybe hint
> > OGC at removing that as well)?
> Bart,
> I'm ok with relaxing the checking. If those interested in
> strict compliance with the specification are not satisfied
> with this approach then I think we would need to revisit RFC 35.
I'm okay with this for GetFeatureInfo. Yes, we should communicate w/
OGC in the same way that we did for STYLES=
> > -does this warrant a 5.0.3 release?
> I would think we role this into 5.0 branch and we issue a
> 5.0.3 release when we have enough fixes to justify it. You
> can certainly deploy the changes in your servers sooner than
> 5.0.3 is issued.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGeo,
> http://osgeo.org
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
