[mapserver-dev] Farsi right-to-left labels
Alan Boudreault
aboudreault at mapgears.com
Sat Mar 15 15:53:07 EDT 2008
Yes fribidi2 have the joining implemented. I just get the confirmation
from Behdad Esfahbod on the mailing list.
I surely going to try it this week.
Alan
Stephen Woodbridge wrote:
> I also came across fribidi2 whiich looks like it already has the
> joining code implemented
> http://www.google.com/search?num=100&hl=en&newwindow=1&q=fribidi2
> and looks like it might be "rev 2" of the GNU fribidi code.
> Daniel, let me know if I can help you with test cases. I have a lot of
> data with Arabic in it although I can not read Arabic myself. I could
> use this now if we had a patch or it was in svn instead of adding a
> new column and populating it with the Perl script.
> Thanks,
> -Steve W
> Alan Boudreault wrote:
>> Hi,
>> I moved the thread in the mapserver-dev because i think it's the
>> right place to be. :)
>> I apply manually the patch from
>> http://trac.osgeo.org/mapserver/ticket/956 to mapserver 5. It's
>> working properly, but doesnt have the joining.
>> This patch use the GNU FriBidi library. The lastest stable version
>> don't support arabic joining, but it seem to be in development. I
>> don't know how is the progress for this support (i just subcribe the
>> fribidi mailing list to have more information) but would you not
>> rather wait for Lib Fribidi to support arabic joining rather than
>> using yet another library ?
>> I will give you more information later about the support of arabic
>> joining.
>> Alan
>>> Yes, I have used arabjoin.pl for the perl version
>>> http://user.cs.tu-berlin.de/~czyborra/arabjoin/arabjoin
>>> and I just started looking for a C langauge version and there a few
>>> variations based on:
>>> http://www.koders.com/c/fid0CDEEAE48A82518AB622E67323B84AB525772AED.aspx?s=mp3
>>> http://www.koders.com/c/fidD92D7571C80226F5F767189298750ACC8461B090.aspx?s=mp3
>>> http://www.koders.com/c/fid6998723CE404855329383741EACE2197511ACDB6.aspx?s=mp3
>>> This is a variation on the above but has a more complete and useful
>>> example, and it will also handle Hebrew, Arabic, and maybe Farsi
>>> http://www.google.com/url?sa=t&ct=res&cd=1&url=http%3A%2F%2F130.89.160.166%2Frockbox%2Farabjoin.c&ei=rlPYR6-8DZjEgQT43tymBQ&usg=AFQjCNFUtcluvex5eicUU4b70H_ok5vC7Q&sig2=m8TZs2uMbL8Te8f2Za0fVQ
>>> http://www.google.com/search?num=100&hl=en&lr=&as_qdr=all&q=arabjoin.c++stdbool.h
>>> -Steve W.
>>>>> Hi Daniel,
>>>>> I looked at the patch briefly.
>>>>> It doesn't seem to be doing character joining for works in Arabic.
>>>>> I'm thinking that if we had the algorithm to do the joining then
>>>>> we could add that and maybe a Tag or metadata item that enabled
>>>>> the joining if needed. The joining algorithm, might be smart
>>>>> enough to only join Arabic letters and leave the rest alone.
>>>>> If you are interested, I think I can get my hands on a perl script
>>>>> that does the joining.
>>>> Steve,
>>>> Isn't is what the function shape_arabic (from the PostArabic)
>>>> module does? If that is the case, the source code in C and an
>>>> original perl source code are available on the web.
>>>> Best Regards,
>>>>> -Steve W
>>>>> Daniel Morissette wrote:
>>>>>> Copying what I wrote earlier this morning on the ka-map list
>>>>>> (sorry for those on both lists):
>>>>>> FYI there is an open MapServer ticket about this:
>>>>>> The ticket even includes a patch that you may want to try. I'll
>>>>>> try to address this one for MapServer 5.2.
>>>>>> Daniel
>>>>>> R Isfahani wrote:
>>>>>>> Hi,
>>>>>>> I'm trying to render some Farsi (Persian) labels on my map. As
>>>>>>> you may know, Farsi words are written from right to left, just
>>>>>>> like Hebrew.
>>>>>>> I've changed the label's encoding to 'Windows-1256' in my
>>>>>>> mapfile and I'm using TrueType fonts. Farsi letters have
>>>>>>> appeared. But the problem is that letters are in revers order
>>>>>>> and letters are not joining properly.
>>>>>>> Of course reversing the letters' order in database will cause
>>>>>>> the right order of them when rendering the map. But I wanna know
>>>>>>> if there's any other way to show farsi labels in right order
>>>>>>> with no joining problems.
>>>>>>> [Actually, I'm using Ka-Map on the top of Mapserver to render my
>>>>>>> maps on the web. Ka-Mappers told me that my problem is a kind of
>>>>>>> Mapserver problems]
>>>>>>> Any new ideas are welcomed.
>>>>>>> Thanx.
>>>>>> _______________________________________________
>>>>>> mapserver-users mailing list
>>>>>> mapserver-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Alan Boudreault
Mapgears
http://www.mapgears.com
