[mapserver-dev] PROJ4 and EPSG database
Yewondwossen Assefa
yassefa at dmsolutions.ca
Thu Feb 12 13:00:46 EST 2009
Frank Warmerdam wrote:
> Folks,
> I would point out that MapServer already has a concept of axis ordering
> implemented for WCS. Of note are the msAxisNormalizePoints() and
> msAxisDenormalizePoints() functions in mapproject.c. These are tied to
> epsgaxis= settings which can be "en" for easting,northing or "ne" for
> northing,easting.
> Currently mapfile.c's proj init function has a special case to set this
> parameter for EPSG urn's in a particular range. In the short term I
> think this is the logical mechanism to extend when working on WMS 1.3.0.
Frank,
This is exactly how I am implementing the proj support for wms1.3.0:
extend the functions to support more CRS codes and the AUTO2. The only
difference that I saw from WCS1.1 would be to allow all EPSG projection
strings (given as Urns or just ESPG:XXXX) to pass though the functions
to set the axes order for those particular ESPG ranges.
Assefa
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
