[mapserver-dev] msautotest-wxs: how to suppress the
header information?
Normand Savard
nsavard at mapgears.com
Tue Mar 17 10:10:23 EDT 2009
Tamas Szekeres wrote:
> Hi All,
> I'm wondering how the msautotest should be executed on windows. Currently I
> get much of the failures because mapserv provides the result with the
> content-type included at the beginning of each file (including the png-s)
> which is compared to the expected files without having that extra
> information.
> Is there a way to suppress this header inclusion without touching the code?
> (I know mapserv has the '-nh' option but it seems mstestlib.py should be
> changed to include this switch)
Tamas,
I checked how the tests works in mstestlib.py and the generated output.
When it's an wxs tests, if the output result is a png file, it's passed
through the demime_file() function. This function is called when
[RESULT_DEMIME] is part of the RUN_PARMS request. It removes the
Content-type.
For the other tests like the ones in gdal or misc, shp2img is used and
there is no such thing as Content-type in the png generated.
Maybe I'm missing something so please do not hesitate to comment.
Norm
def demime_file( filename ):
data = open(filename,'rb').read()
for i in range(len(data)-1):
if data[i] == '\n' and data[i+1] == '\n':
open(filename,'wb').write(data[i+2:])
return
return
