[mapserver-dev] The "Query feature" not working for my application
Sumit Sharma
sumit321 at hotmail.com
Mon Nov 16 02:40:20 EST 2009
are you setting template of layer... set it to dummy, before making query, it
worked for me!
sharat wrote:
> I am using the mapserver Itasca demo application using my own maps. But
> the query feature option doesn't seem to work.
> Every time i click on the map, it just outputs this "msQueryByPoint():
> Search returned no results. No matching record(s) found"
> I am new to mapserver. and i need some help in getting the query feature
> working. As per the above output what is the immediate thing that i need
> to do OR what are the things i need to check.
> Any help will be greatly appreciated.
> Thanks,
> Sharat
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
View this message in context: http://n2.nabble.com/The-Query-feature-not-working-for-my-application-tp3942539p4010705.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
