[mapserver-dev] Error compiling MapServer Trunk on Windows
Debasish Sahu
debasish.sahu at gmail.com
Thu Oct 8 05:37:24 EDT 2009
I had downloaded the BuildKit from
http://www.gatewaygeomatics.com/dl/buildkit/ and the source code contained
in the kit complied without any problems. Then I replaced the mapserver
source with the latest code from SVN trunk and tried to build but without
success. I am getting the following errors
Creating library mapserver_i.lib and object mapserver_i.exp
maplegend.obj : error LNK2019: unresolved external symbol _msDrawShadeSymbol
ref
erenced in function _msDrawLegendIcon
mapdraw.obj : error LNK2001: unresolved external symbol _msDrawShadeSymbol
mapgeomtransform.obj : error LNK2001: unresolved external symbol
_msDrawShadeSym
bol
maplegend.obj : error LNK2019: unresolved external symbol _msDrawLineSymbol
refe
mapdraw.obj : error LNK2001: unresolved external symbol _msDrawLineSymbol
mapgeomtransform.obj : error LNK2019: unresolved external symbol
_msDrawMarkerSy
mbol referenced in function _msDrawTransformedShape
maplegend.obj : error LNK2001: unresolved external symbol
_msDrawMarkerSymbol
mapscale.obj : error LNK2001: unresolved external symbol _msDrawMarkerSymbol
mapraster.obj : error LNK2001: unresolved external symbol
_msDrawMarkerSymbol
mapdraw.obj : error LNK2001: unresolved external symbol _msDrawMarkerSymbol
maputil.obj : error LNK2019: unresolved external symbol _msSaveRasterBuffer
refe
renced in function _msSaveImage
_msSaveRasterBufferToBuf
fer referenced in function _msSaveImageBuffer
mapdraw.obj : error LNK2019: unresolved external symbol _msDrawText
referenced i
n function _msDrawLabel
mapdraw.obj : error LNK2019: unresolved external symbol _msDrawTextLine
referenc
ed in function _msDrawLabelCache
_msCircleDrawShadeSymbol
referenced in function _msDrawShape
mapoutput.obj : error LNK2019: unresolved external symbol
_msPopulateRendererVTa
bleOGL referenced in function _msInitializeRendererVTable
bleCairoSVG referenced in function _msInitializeRendererVTable
bleCairoPDF referenced in function _msInitializeRendererVTable
bleCairoRaster referenced in function _msInitializeRendererVTable
mapagg.obj : error LNK2001: unresolved external symbol "unsigned char const
* co
nst mapserver::gse8x16_bold" (?gse8x16_bold at mapserver@@3QBEB)
* co
nst mapserver::gse7x15" (?gse7x15 at mapserver@@3QBEB)
* co
nst mapserver::gse7x11_bold" (?gse7x11_bold at mapserver@@3QBEB)
* co
nst mapserver::gse7x11" (?gse7x11 at mapserver@@3QBEB)
* co
nst mapserver::gse5x7" (?gse5x7 at mapserver@@3QBEB)
mapagg.obj : error LNK2019: unresolved external symbol "unsigned short *
mapserv
er::g_sqrt_table" (?g_sqrt_table at mapserver@@3PAGA) referenced in function
"unsig
ned int __cdecl mapserver::fast_sqrt(unsigned int)" (?fast_sqrt at mapserver
@@YAII@
Z)
mapagg.obj : error LNK2019: unresolved external symbol "public: static
unsigned
char const * const mapserver::line_parameters::s_diagonal_quadrant"
(?s_diagonal
_quadrant at line_parameters@mapserver@@2QBEB) referenced in function "public:
unsi
gned int __thiscall mapserver::line_parameters::diagonal_quadrant(void)const
?diagonal_quadrant at line_parameters@mapserver@@QBEIXZ)
mapagg.obj : error LNK2019: unresolved external symbol "public: void
__thiscall
mapserver::curve3_div::init(double,double,double,double,double,double)"
(?init at c
urve3_div at mapserver@@QAEXNNNNNN at Z) referenced in function "public: void
__thisca
ll mapserver::curve3::init(double,double,double,double,double,double)"
(?init at cu
rve3 at mapserver@@QAEXNNNNNN at Z)
__thiscall
mapserver::curve3_inc::init(double,double,double,double,double,double)"
(?init at c
urve3_inc at mapserver@@QAEXNNNNNN at Z) referenced in function "public: void
__thisca
(?init at cu
__thiscall
mapserver::curve4_div::init(double,double,double,double,double,double,double,dou
ble)" (?init at curve4_div@mapserver@@QAEXNNNNNNNN at Z) referenced in function
"publi
c: void __thiscall
mapserver::curve4::init(double,double,double,double,double,do
uble,double,double)" (?init at curve4@mapserver@@QAEXNNNNNNNN at Z)
__thiscall
mapserver::curve4_inc::init(double,double,double,double,double,double,double,dou
ble)" (?init at curve4_inc@mapserver@@QAEXNNNNNNNN at Z) referenced in function
"publi
c: void __thiscall
mapagg.obj : error LNK2019: unresolved external symbol "public: struct
mapserver
::trans_affine const & __thiscall mapserver::trans_affine::multiply(struct
mapse
rver::trans_affine const &)" (?multiply at trans_affine@mapserver@
@QAEABU12 at ABU12@@
Z) referenced in function "public: struct mapserver::trans_affine const &
__this
call mapserver::trans_affine::operator*=(struct mapserver::trans_affine
const &)
" (??Xtrans_affine at mapserver@@QAEABU01 at ABU01@@Z)
mapagg.obj : error LNK2019: unresolved external symbol "public: __thiscall
mapse
rver::font_engine_freetype_base::font_engine_freetype_base(bool,unsigned
int)" (
??0font_engine_freetype_base at mapserver@@QAE at _NI@Z) referenced in function
"publi
c: __thiscall
mapserver::font_engine_freetype_int16::font_engine_freetype_int16(
unsigned int)" (??0font_engine_freetype_int16 at mapserver@@QAE at I@Z)
mapse
rver::font_engine_freetype_base::~font_engine_freetype_base(void)"
(??1font_engi
ne_freetype_base at mapserver@@QAE at XZ) referenced in function "public:
__thiscall m
apserver::font_engine_freetype_int16::~font_engine_freetype_int16(void)"
(??1fon
t_engine_freetype_int16 at mapserver@@QAE at XZ)
mapagg.obj : error LNK2019: unresolved external symbol "public: unsigned int
__t
hiscall mapserver::vcgen_contour::vertex(double *,double *)"
(?vertex at vcgen_cont
our at mapserver@@QAEIPAN0 at Z) referenced in function "public: unsigned int
__thisca
ll mapserver::conv_adaptor_vcgen<class mapserver::path_base<class
mapserver::ver
tex_block_storage<double,8,256> >,class mapserver::vcgen_contour,struct
mapserve
r::null_markers>::vertex(double *,double *)" (?vertex@?$conv_adaptor_vcgen at V
?$pa
th_base at V?$vertex_block_storage at N$07$0BAA@@mapserver@@@mapserver@
@Vvcgen_contour
@2 at Unull_markers@2@@mapserver@@QAEIPAN0 at Z)
__thiscall
mapserver::vcgen_contour::rewind(unsigned int)" (?rewind at vcgen_contour
@mapserver
@@QAEXI at Z) referenced in function "public: unsigned int __thiscall
mapserver::co
mapserver::vertex_block_storag
mapserver::null_markers>
::vertex(double *,double *)" (?vertex@?$conv_adaptor_vcgen at V?$path_base at V
?$verte
x_block_storage at N$07$0BAA@@mapserver@@@mapserver@@Vvcgen_contour at 2
@Unull_markers
__thiscall
mapserver::vcgen_contour::add_vertex(double,double,unsigned int)"
(?add_vertex at v
cgen_contour at mapserver@@QAEXNNI at Z) referenced in function "public: unsigned
int
__thiscall mapserver::conv_adaptor_vcgen<class mapserver::path_base<class
mapser
ver::vertex_block_storage<double,8,256> >,class
mapserver::null_markers>::vertex(double *,double *)" (?vertex@
?$conv_adaptor_vcg
en at V?$path_base at V?$vertex_block_storage at N$07$0BAA@@mapserver@@@mapserver@
@Vvcgen
_contour at 2@Unull_markers at 2@@mapserver@@QAEIPAN0 at Z)
__thiscall
mapserver::vcgen_contour::remove_all(void)" (?remove_all at vcgen_contour
@mapserver
@@QAEXXZ) referenced in function "public: unsigned int __thiscall
mapserver::con
mapserver::vertex_block_storage
Thanks and Warm Regards
Debasish Sahu
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20091008/bfb47a08/attachment-0001.html
