[mapserver-dev] Error compiling MapServer Trunk on Windows
Tamas Szekeres szekerest at gmail.com
Thu Oct 8 14:27:04 EDT 2009
Didn't you replace the makefile (makefile.vc, nmake.opt) of the SVN trunk
with an older version?
You could also download either of the SDK packages (depending on your
compiler/architecture) from this location at the bottom of the page:
http://vbkto.dyndns.org/sdk/
Extract the SDK files in a directory and type 'nmake ms' in a Visual Studio
Command Prompt
Best regards,
Tamas
2009/10/8 Debasish Sahu <debasish.sahu at gmail.com>
> Hi,
> I had downloaded the BuildKit from
> http://www.gatewaygeomatics.com/dl/buildkit/  and the source code
> contained in the kit complied without any problems. Then I replaced the
> mapserver source with the latest code from SVN trunk and tried to build but
> without success. I am getting the following errors
>    Creating library mapserver_i.lib and object mapserver_i.exp
> maplegend.obj : error LNK2019: unresolved external symbol
> _msDrawShadeSymbol ref
> erenced in function _msDrawLegendIcon
> mapdraw.obj : error LNK2001: unresolved external symbol _msDrawShadeSymbol
> mapgeomtransform.obj : error LNK2001: unresolved external symbol
> _msDrawShadeSym
> bol
> maplegend.obj : error LNK2019: unresolved external symbol _msDrawLineSymbol
> refe
> mapdraw.obj : error LNK2001: unresolved external symbol _msDrawLineSymbol
> mapgeomtransform.obj : error LNK2019: unresolved external symbol
> _msDrawMarkerSy
> mbol referenced in function _msDrawTransformedShape
> maplegend.obj : error LNK2001: unresolved external symbol
> _msDrawMarkerSymbol
> mapscale.obj : error LNK2001: unresolved external symbol
> _msDrawMarkerSymbol
> mapraster.obj : error LNK2001: unresolved external symbol
> _msDrawMarkerSymbol
> mapdraw.obj : error LNK2001: unresolved external symbol _msDrawMarkerSymbol
> maputil.obj : error LNK2019: unresolved external symbol _msSaveRasterBuffer
> refe
> renced in function _msSaveImage
> _msSaveRasterBufferToBuf
> fer referenced in function _msSaveImageBuffer
> mapdraw.obj : error LNK2019: unresolved external symbol _msDrawText
> referenced i
> n function _msDrawLabel
> mapdraw.obj : error LNK2019: unresolved external symbol _msDrawTextLine
> referenc
> ed in function _msDrawLabelCache
> _msCircleDrawShadeSymbol
>  referenced in function _msDrawShape
> mapoutput.obj : error LNK2019: unresolved external symbol
> _msPopulateRendererVTa
> bleOGL referenced in function _msInitializeRendererVTable
> bleCairoSVG referenced in function _msInitializeRendererVTable
> bleCairoPDF referenced in function _msInitializeRendererVTable
> bleCairoRaster referenced in function _msInitializeRendererVTable
> mapagg.obj : error LNK2001: unresolved external symbol "unsigned char const
> * co
> nst mapserver::gse8x16_bold" (?gse8x16_bold at mapserver@@3QBEB)
> * co
> nst mapserver::gse7x15" (?gse7x15 at mapserver@@3QBEB)
> * co
> nst mapserver::gse7x11_bold" (?gse7x11_bold at mapserver@@3QBEB)
> * co
> nst mapserver::gse7x11" (?gse7x11 at mapserver@@3QBEB)
> * co
> nst mapserver::gse5x7" (?gse5x7 at mapserver@@3QBEB)
> mapagg.obj : error LNK2019: unresolved external symbol "unsigned short *
> mapserv
> er::g_sqrt_table" (?g_sqrt_table at mapserver@@3PAGA) referenced in function
> "unsig
> ned int __cdecl mapserver::fast_sqrt(unsigned int)" (?fast_sqrt at mapserver
> @@YAII@
> Z)
> mapagg.obj : error LNK2019: unresolved external symbol "public: static
> unsigned
> char const * const mapserver::line_parameters::s_diagonal_quadrant"
> (?s_diagonal
> _quadrant at line_parameters@mapserver@@2QBEB) referenced in function
> "public: unsi
> gned int __thiscall
> mapserver::line_parameters::diagonal_quadrant(void)const " (
> ?diagonal_quadrant at line_parameters@mapserver@@QBEIXZ)
> mapagg.obj : error LNK2019: unresolved external symbol "public: void
> __thiscall
> mapserver::curve3_div::init(double,double,double,double,double,double)"
> (?init at c
> urve3_div at mapserver@@QAEXNNNNNN at Z) referenced in function "public: void
> __thisca
> ll mapserver::curve3::init(double,double,double,double,double,double)"
> (?init at cu
> rve3 at mapserver@@QAEXNNNNNN at Z)
> __thiscall
> mapserver::curve3_inc::init(double,double,double,double,double,double)"
> (?init at c
> urve3_inc at mapserver@@QAEXNNNNNN at Z) referenced in function "public: void
> __thisca
> (?init at cu
> __thiscall
> mapserver::curve4_div::init(double,double,double,double,double,double,double,dou
> ble)" (?init at curve4_div@mapserver@@QAEXNNNNNNNN at Z) referenced in function
> "publi
> c: void __thiscall
> mapserver::curve4::init(double,double,double,double,double,do
> uble,double,double)" (?init at curve4@mapserver@@QAEXNNNNNNNN at Z)
> __thiscall
> mapserver::curve4_inc::init(double,double,double,double,double,double,double,dou
> ble)" (?init at curve4_inc@mapserver@@QAEXNNNNNNNN at Z) referenced in function
> "publi
> c: void __thiscall
> mapagg.obj : error LNK2019: unresolved external symbol "public: struct
> mapserver
> ::trans_affine const & __thiscall mapserver::trans_affine::multiply(struct
> mapse
> rver::trans_affine const &)" (?multiply at trans_affine@mapserver@
> @QAEABU12 at ABU12@@
> Z) referenced in function "public: struct mapserver::trans_affine const &
> __this
> call mapserver::trans_affine::operator*=(struct mapserver::trans_affine
> const &)
> " (??Xtrans_affine at mapserver@@QAEABU01 at ABU01@@Z)
> mapagg.obj : error LNK2019: unresolved external symbol "public: __thiscall
> mapse
> rver::font_engine_freetype_base::font_engine_freetype_base(bool,unsigned
> int)" (
> ??0font_engine_freetype_base at mapserver@@QAE at _NI@Z) referenced in function
> "publi
> c: __thiscall
> mapserver::font_engine_freetype_int16::font_engine_freetype_int16(
> unsigned int)" (??0font_engine_freetype_int16 at mapserver@@QAE at I@Z)
> mapse
> rver::font_engine_freetype_base::~font_engine_freetype_base(void)"
> (??1font_engi
> ne_freetype_base at mapserver@@QAE at XZ) referenced in function "public:
> __thiscall m
> apserver::font_engine_freetype_int16::~font_engine_freetype_int16(void)"
> (??1fon
> t_engine_freetype_int16 at mapserver@@QAE at XZ)
> mapagg.obj : error LNK2019: unresolved external symbol "public: unsigned
> int __t
> hiscall mapserver::vcgen_contour::vertex(double *,double *)"
> (?vertex at vcgen_cont
> our at mapserver@@QAEIPAN0 at Z) referenced in function "public: unsigned int
> __thisca
> ll mapserver::conv_adaptor_vcgen<class mapserver::path_base<class
> mapserver::ver
> tex_block_storage<double,8,256> >,class mapserver::vcgen_contour,struct
> mapserve
> r::null_markers>::vertex(double *,double *)" (?vertex@
> ?$conv_adaptor_vcgen at V?$pa
> th_base at V?$vertex_block_storage at N$07$0BAA@@mapserver@@@mapserver@
> @Vvcgen_contour
> @2 at Unull_markers@2@@mapserver@@QAEIPAN0 at Z)
> __thiscall
> mapserver::vcgen_contour::rewind(unsigned int)" (?rewind at vcgen_contour
> @mapserver
> @@QAEXI at Z) referenced in function "public: unsigned int __thiscall
> mapserver::co
> mapserver::vertex_block_storag
> mapserver::null_markers>
> ::vertex(double *,double *)" (?vertex@?$conv_adaptor_vcgen at V?$path_base at V
> ?$verte
> x_block_storage at N$07$0BAA@@mapserver@@@mapserver@@Vvcgen_contour at 2
> @Unull_markers
> __thiscall
> mapserver::vcgen_contour::add_vertex(double,double,unsigned int)"
> (?add_vertex at v
> cgen_contour at mapserver@@QAEXNNI at Z) referenced in function "public:
> unsigned int
> __thiscall mapserver::conv_adaptor_vcgen<class mapserver::path_base<class
> mapser
> ver::vertex_block_storage<double,8,256> >,class
> mapserver::null_markers>::vertex(double *,double *)" (?vertex@
> ?$conv_adaptor_vcg
> en at V?$path_base at V?$vertex_block_storage at N$07$0BAA@@mapserver@@@mapserver@
> @Vvcgen
> _contour at 2@Unull_markers at 2@@mapserver@@QAEIPAN0 at Z)
> __thiscall
> mapserver::vcgen_contour::remove_all(void)" (?remove_all at vcgen_contour
> @mapserver
> @@QAEXXZ) referenced in function "public: unsigned int __thiscall
> mapserver::con
> mapserver::vertex_block_storage
> Thanks and Warm Regards
> Debasish Sahu
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20091008/e53653eb/attachment.html
