[mapserver-dev] Error compiling MapServer Trunk on Windows
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Oct 8 19:10:19 EDT 2009
Debasish Sahu wrote:
> Hi,
> I had downloaded the BuildKit from
> http://www.gatewaygeomatics.com/dl/buildkit/ and the source code
> contained in the kit complied without any problems. Then I replaced the
> mapserver source with the latest code from SVN trunk and tried to build
> but without success. I am getting the following errors
Hello Debasish,
It definitely tricky changing the nmake.opt for trunk or another release
with the buildkit paths (indeed I am facing the issue with Beta3,
wondering if it is my own path problems or not). What I do is do a diff
from the last working build nmake.opt to the one you are working
on....but it's difficult. It's very easy with Unix, but difficult with
Windows.
-jeff
Jeff McKenna
FOSS4G Consulting and Training Services
