[mapserver-dev] Error compiling MapServer Trunk on Windows
Tamas Szekeres szekerest at gmail.com
Fri Oct 9 14:26:08 EDT 2009
Hi Jeff,
You can customize the things without having to change the nmake.opt, by
creating your custom nmake.opt let's say mynmake.opt and specify that in the
nmake command line:
nmake -f makefile.vc EXT_NMAKE_OPT=mynmake.opt.
This option is exensively used in practice by the buildbot windows slaves.
Best regards,
Tamas
2009/10/9 Jeff McKenna <jmckenna at gatewaygeomatics.com>
> Debasish Sahu wrote:
>> Hi,
>> I had downloaded the BuildKit from
>> http://www.gatewaygeomatics.com/dl/buildkit/  and the source code
>> contained in the kit complied without any problems. Then I replaced the
>> mapserver source with the latest code from SVN trunk and tried to build but
>> without success. I am getting the following errors
> Hello Debasish,
> It definitely tricky changing the nmake.opt for trunk or another release
> with the buildkit paths (indeed I am facing the issue with Beta3, wondering
> if it is my own path problems or not).  What I do is do a diff from the last
> working build nmake.opt to the one you are working on....but it's difficult.
>  It's very easy with Unix, but difficult with Windows.
> -jeff
> Jeff McKenna
> FOSS4G Consulting and Training Services
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
URL: http://lists.osgeo.org/pipermail/mapserver-dev/attachments/20091009/e9145706/attachment.html
