[mapserver-dev] Unable to access MapInfo TAB files or ESRI
Shape Files
Sumit Sharma
sumit321 at hotmail.com
Tue Oct 20 02:49:56 EDT 2009
I suggest to revisit your map file. your possible errors can be with style
obj of your layer or with your map extents. If still you are not able to
figure out, u can share your map file and shape file(s)
Cheers,
Sumit
sharat wrote:
> I am newbie to mapserver. I have MapInfo .tab files and also shape files.
> When i try to access them as layers using an OGR connection, the layers
> just don't show up. I am using the basic ITASCA demo that is available for
> download. I've made according modifications and gave OGR connections. I'm
> really not able to figure out the reason. I'm sure its a small issue, but
> i'm just not able to get out of it.
> If anyone could tell me the possible reasons for the layers not to show
> up, i will look into them. Any help regd this is greatly appreciated.
> Thanks,
> Sharat
> mapserver-dev mailing list
> mapserver-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
View this message in context: http://n2.nabble.com/Unable-to-access-MapInfo-TAB-files-or-ESRI-Shape-Files-tp3849353p3857077.html
Sent from the Mapserver - Dev mailing list archive at Nabble.com.
